What is the Definition of Frustration in Physics?
  • Context: Graduate
  • Thread starter Thread starter badphysicist
    Definition
Frustration in physics refers to a system's inability to achieve a minimum energy configuration for all entities involved. In the context of the antiferromagnetic Heisenberg model on a triangular lattice, the ground state cannot be the Néel state due to the presence of unhappy bonds, resulting in a canted antiferromagnetic arrangement. Frustration can arise from geometric configurations or competition between interactions, as seen in the square lattice antiferromagnetic Heisenberg model with non-nearest neighbor exchanges. Doping in antiferromagnets leads to 'Coulomb frustrated phase separation,' where the material forms regions rich and poor in holes due to Coulomb interactions.
  • Understanding of antiferromagnetic Heisenberg models
  • Familiarity with triangular and square lattice structures
  • Knowledge of kinetic energy concepts in solid-state physics
  • Basic principles of Coulomb interactions in materials
  • Research the antiferromagnetic Heisenberg model on triangular lattices
  • Explore the concept of canted antiferromagnetic arrangements
  • Study the effects of doping on antiferromagnetic materials
  • Investigate Coulomb frustrated phase separation in superconductors
Physicists, materials scientists, and researchers studying superconductivity and magnetic systems will benefit from this discussion on frustration in physics.
badphysicist
I've been wondering what a good definition of frustration is in physics (plenty of bad jokes could be made here). I've been reading a lot of superconductivity papers and keep finding the term. I can understand how it makes sense in some situations, but not others. For instance, in one paper I find the phrase 'the kinetic energy of doped holes is frustrated in an antiferromagnet.' What does this mean?
Thanks,
A Bad Physicist
Frustration occurs when a system is unable to simultaneously achieve a minimum energy for each entity involved. For example, if you take the antiferromagnetic Heisenberg model on a triangular lattice, the ground state cannot be the Néel state, since there will always be one unhappy bond. The system has to come to a compromise, and the ground state is some canted antiferromagnetic arrangement.
It occurs for other things than non-bipartite lattices as well. If you take the square lattice antiferromagnetic Heisenberg lattice and include exchanges other than nearest neighbour, you can frustrate the system.
So, frustration can either occur for geometric reasons, as in the first example, or due to competition between interactions, as in the second.
In your example, suppose we have a nice Néel ordered antiferromagnet in the parent compound. When you start doping, you will remove one of the spins, and thus break two bonds. The hole cannot move around without breaking more bonds, or putting two of the same spin next to each other. This leads to something that is named in the literature 'stripes'.
The Coulomb interaction prevents the material from phase separating into a bunch of electrons in one part of the material, and a bunch of holes on the other. So, the material splits into a pattern of hole rich and hole poor regions. This is 'Coulomb frustrated phase separation' in the literature.
Thank you. That helps a lot.
  • · Replies 23 ·
  • · Replies 43 ·
  • · Replies 18 ·
  • · Replies 16 ·
