Does Counterbalancing Weight Differ From Concrete Weight in a Spinning Mould?
The discussion centers on the need for counterbalancing weight when forming a concrete utility pole with an aperture in a spinning mould. The user seeks to determine if the counterbalancing weight required differs from the concrete's estimated weight of 403 lbs due to its placement outside the mould. The physics involved suggests that the counterbalance must account for the dynamics of the spinning process, specifically the centripetal forces acting on the pole. A precise calculation factor is necessary to ensure stability during the moulding process.
  • Understanding of centripetal force in rotating systems
  • Basic principles of civil engineering related to concrete forming
  • Knowledge of weight distribution and balance in mechanical systems
  • Familiarity with the physics of rotating bodies
  • Research the principles of centripetal force and its impact on rotating objects
  • Study weight distribution techniques in civil engineering applications
  • Learn about the calculations for counterbalancing in rotating systems
  • Explore the effects of external weights on the stability of spinning moulds
Civil engineers, mechanical engineers, and professionals involved in concrete forming and moulding processes will benefit from this discussion, particularly those interested in optimizing stability and balance in rotating systems.
lwasmund
I am forming a concrete utility pole centripetaly in the mould (lathe). I need to have it form with an aperature(box shaped hole). I need to place a box to form the hole for the aperature and it needs to be of proper weight. the weight the concrete would of been had there been no aperture. It is best if i place the box in without it being of the desired weight, and counter balance it on the outside of the mould. My question is would the wieght needed to counterbalance the pole when spinning need to be different then the aproximated weight of the concrete(403lbs). Since the weight is on the outside of the mould?
thanks
I understand a little about physics. My main study is civil eng. I am looking for the factor that I can add to my equation to calculate for the difference with the counterbalance being on the outside. think of a ball on a string. except no the ball isn't on a string but held in orbit by the perimeter. How much mass/weight do I need to counterbalance. When it is to counter 403lbs of misplaced concrete.
  • · Replies 27 ·
12K
  • · Replies 17 ·
13K
12K
