Register to reply
Microscope to view sample in focus with a completely relaxed eye
by Niki4444
Tags: infinity, lenght, lens, microscope, physics
Share this thread:
Niki4444
#1
Jul20-08, 01:46 PM
P: 9
A microscope has a converging lens (eyepiece) with focal length of 2.50 cm mounted on one end of a tube of adjustable length. At the other end is another converging lens (objective) with a focal length of 1.00 cm. When you place the sample 1.30 cm from the objective, what length, l, will you need to adjust the tube of the microscope to view the sample in focus with a completely relaxed eye. It then explains that to view sample with a completely relaxed eye, the eyepiece must form its image at infinity.
2. Relevant equations
f(eyepiece)=2.50 cm
f(objective)=1.00 cm
L=adjustable
1/f=1/s+1/s'
Mo=-s'/s
Me=25/f(eyepiece)
M=(Mo)(Me)=-(L/fo)(25 cm/f(eyepiece))
3. The attempt at a solution
so, for the objective lens,
1/f=1/s+1/s'
1/1=1/1.3+1/s'
solve for s' and get 4.3 cm
so, for the eyepiece lens,
1/f=1/s+1/s'
1/2.5=1/2.5+1/infinity
so, I thought s would be close to 2.5
so, Mo=-(4.3)/(1.3)=-3.3
so, Me=25/2.5=10
so, M=(Mo)(Me)=(-3.3)(10)=-33.1
M=-33.1=(-L)/(fo)*(25/fe)
-33.1=-L/1*25/2.5
solving for L, I get 3.31 cm which is incorrect
Any ideas to push me toward a better solution? Thanks again for your help.
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
G01
#2
Jul20-08, 02:34 PM
HW Helper
G01's Avatar
P: 2,688
I don't see why you need to use magnification to solve this problem. I think your making this harder than it has to be.
The length of the tube, L, must be long enough to contain the distance of the first image from the first lens and the distance from the first image to the second lens. You know the distance of the first image from the first lens is 4.3cm and that the distance from the second lens has to be 2.5 cm. You should be able to find L just from this information.
If you haven't already, try drawing a picture to help you to visualize the setup of this microscope.
Niki4444
#3
Jul20-08, 02:36 PM
P: 9
Thank you for letting me know I'm making physics harder than it needs to be! I certainly don't want to do that. So L is the distance from the object to the final image??
So, you said.....
so L must be 4.3 cm + 2.5 cm??? I guess I don't understand what L is.
G01
#4
Jul20-08, 02:45 PM
HW Helper
G01's Avatar
P: 2,688
Quote Quote by Niki4444 View Post
So, you said.....
Yes. L is the length of the tube between the first and second lens. So if the image is inside the tube, 4.3cm away from one lens and 2.5 cm away from the other, then we can reason that the tube must be 2.5+4.3 = 6.8cm long.
Register to reply
Related Discussions
Sample mean and sample variance Calculus & Beyond Homework 1
A relaxed talk show&opinion poll from Kuwait Current Events 1
Here's a question on light ray optics and focal length. General Physics 11
Focus an axial ray Introductory Physics Homework 1
Statistics: sample median, means, s.d. vs sample size Precalculus Mathematics Homework 2
