Uniform convergence of a series of functions
The discussion revolves around the uniform convergence of two series of functions defined on the interval [0,1]. The first series involves alternating terms and a factor of (1-x), while the second series is a simpler power series. Participants are exploring the conditions under which these series converge uniformly and absolutely.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to prove absolute and uniform convergence for both series, with some showing partial results through induction and limits. Questions about the continuity of limiting functions and the application of uniform convergence tests are raised. There is also a discussion about the validity of restating series and the conditions for uniform convergence.
Some participants have provided insights into the convergence behavior of the series, with attempts to validate approaches and clarify misunderstandings. There are ongoing explorations of mathematical reasoning and the application of convergence tests, but no consensus has been reached yet.
Participants are working under the constraints of proving convergence without providing complete solutions, and there are indications of confusion regarding the formulation of the series and the necessary conditions for uniform convergence.
linearfish
Prove:
(1) the series
[tex]\sum_{n=0}^\infty (-1)^n x^n (1-x)[/tex]
converges absolutely and uniformly on the interval [0,1]
(2) the series
[tex]\sum_{n=0}^\infty x^n (1-x)[/tex]
I have shown, by induction, that the limiting function of the second series is 1 - xn+1, which goes to 1. Thus the series of functions converges (absolutely, since all values are positive) but is 0 at x = 1, so thus not continuous. Therefore, the convergence of the second series is not uniform. However, this also shows that the first series converges absolutely.
Where I am stuck is with uniform convergence of the first series. Using partial sums I was able to show that the series converges to (1-x)/(1+x), but how do I show this is uniform? I don't think it's enough to say that the limiting function is continuous in the given interval.
Can anyone tell me if I'm on the right track or what I can use to prove uniform convergence? Thanks.
Let [tex]\epsilon \in \mathbb{R}[/tex]. Show that for all [tex]\epsilon > 1[/tex], [tex]\sum_n \left ( {-1 \over \epsilon} \right ) (\epsilon x)^n (1-x)[/tex] satisfies Abel's Uniform Convergence Test.
I'm afraid I don't quite understand your restatement of series. Is it missing a power of n on the first term?
If that's the case, then I believe I need to show the following:
1. [tex]{( \epsilon x)^n }[/tex] is uniformly bounded and eventually monotonic.
2. [tex]\sum_{n=0}^\infty {\left(\frac{1}{\epsilon}\right)}^n (1-x)[/tex] converges uniformly
Is this correct? Thanks.
Let me try this:
I claim:
[tex]\sum_{n=0}^N (-1)^n x^n (1-x) = (1-x) \frac{1 - (-x)^{N+1}}{1+x}[/tex]
[tex]\sum_{n=0}^{\infty} (-1)^n x^n (1-x) = \frac{1-x}{1+x}[/tex]
If the first converges uniformly to the second, then as n goes to infinity:
[tex]\left| (1-x) \left(\frac{1 - (-x)^{N+1}}{1+x}-\frac{1}{1+x}\right)\right| \rightarrow 0[/tex]
This is true since:
[tex]\left| (1-x) \left(\frac{1 - (-x)^{N+1}}{1+x}-\frac{1}{1+x}\right)\right| =<br /> \left| \frac{(1-x)}{1+x} (-1) (-x)^{N+1}\right| = (x)^{N+1} \left| \frac{(1-x)}{1+x}\right| \rightarrow 0 (1) = 0[/tex]
Hence the series converges uniformly. Can anyone validate this or pick out a problem with it? Thanks.
Not to bump this thread but I think I have a better solution now:
[tex]\left| (1-x) \left(\frac{1 - (-x)^{N+1}}{1+x}-\frac{1}{1+x}\right)\right| = \frac{1 - x}{1 + x} \left| -(-x)^{N+1} \right| = \frac{1 - x}{1 + x}(x)^{N+1} \leq (1-x)x^{N+1}[/tex]
Keeping in mind that we are on the interval [0,1], we can take the derivative of the last function and, setting it equal to 0, find the the function has a maximum value at x=(N+1)/(N+2). Thus,
[tex]\left| (1-x) \left(\frac{1 - (-x)^{N+1}}{1+x}-\frac{1}{1+x}\right)\right| \leq (1-x)x^{N+1} \leq (1- \frac{N+1}{N+2})(\frac{N+1}{N+2})^{N+1} \leq \frac{1}{N+2}[/tex]
Then this is less than any arbitrary epsilon if
[tex]N > \frac{1}{\epsilon} - 2[/tex]
Since N does not depend on the choice of x, this convergence is uniform.
I think this is the right idea but I'd appreciate any comments or validations. Thanks.
