Deflection of bullet by Earth's magnetic field
The discussion focuses on calculating the deflection of a bullet in Earth's magnetic field, specifically a bullet weighing 0.0034 kg, traveling at 160 m/s, with a charge of 13.5E-9 C in a magnetic field of 5E-5 T. The initial calculations involved determining the radius of the circular path using the formula r = mv/qB, resulting in a radius of 8.1E11 m. The angle of deflection was then calculated using the arc length of 1000 m divided by the radius. The participant was advised to apply the Lorentz magnetic force law to find the bullet's acceleration for a more accurate deflection calculation.
  • Understanding of Lorentz force law
  • Familiarity with circular motion equations
  • Knowledge of basic physics concepts such as mass, charge, and magnetic fields
  • Ability to perform trigonometric calculations
  • Study the application of the Lorentz force law in charged particle motion
  • Learn about circular motion and its relation to magnetic fields
  • Explore advanced trigonometric methods for calculating deflection
  • Investigate the effects of varying magnetic field strengths on charged particles
Physics students, educators, and anyone interested in the dynamics of charged particles in magnetic fields will benefit from this discussion.
jkulier
A 0.0034kg bullet moves with a speed of 160 m/s perpendicular to the Earth's magnetic field of 5E-5 T. If the bullet has a net charge of 13.5E-9 C, by what distance is it deflected due to the magnetic field after it has traveled 1000m?
radius = mv/qB
theta = arc length/radius
First, I found the radius of the circle via: r = (mv)/qB = 8.1E11
Next, I found theta using the arc length of the circle traveled by the bullet divided by the radius of that circle: theta = arc/radius = 1000/8.1E11
Finally, to find the distance it's deflected, I used the triangle approach: tan(theta) = x/1000
However, my answer is incorrect. Any ideas would be great,
thanks in advance.
Just wondering why you wouldn't apply the Lorentz magnetic force law to identify the acceleration the bullet would be subjected to and than apply that to figure deflection?
  • · Replies 17 ·
