Can the Sum of Supremums be Greater than the Supremum of the Sum?
  • Thread starter Thread starter danago
    Supremum
The discussion revolves around the properties of supremums in the context of two non-empty, bounded sets A and B within the positive real numbers. The original poster seeks to understand why the supremum of the sum of these sets is not necessarily equal to the sum of their supremums.
  • The original poster attempts to prove that the supremum of the sum of two sets is less than or equal to the sum of their supremums, but struggles to understand why equality does not hold in general. Participants discuss the implications of upper bounds and the conditions for least upper bounds.
Participants have provided guidance on the nature of the proof required and the distinction between upper bounds and least upper bounds. There is an ongoing exploration of the conditions under which the supremum of the sum could be equal to the sum of the supremums, with some participants questioning the necessity of proving equality.
There is a focus on the definitions and properties of supremums, as well as the implications of the original poster's findings regarding upper bounds. The discussion highlights the original poster's confusion about the requirements of the proof and the nature of the relationships between the sets involved.
danago
Suppose that [tex]A,B \subseteq \Re^+[/tex] are non empty and bounded sets. Define + and . as the following set opetations:
[tex] \begin{array}{l}<br /> A + B = \{ a + b|a \in A,b \in B\} \\ <br /> A.B = \{ ab|a \in A,b \in B\} \\ <br /> \end{array}[/tex]
Prove that [tex]\sup (A + B) \le \sup A + \sup B[/tex]
I started by letting [tex]a \in A,b \in B[/tex]. From the definition of supremum:
[tex] \begin{array}{l}<br /> a \le \sup A \\ <br /> b \le \sup B \\ <br /> \end{array}[/tex]
I then added the two inequalities to give:
[tex] a + b \le \sup A + \sup B[/tex]
Since this holds true for any a and b, sup A+sup B is an upper bound on the set A+B. This is where I am a bit stuck. I can't really see why sup(A+B) isn't strictly equal to sup A + sup B. I tried coming up with a few example sets A and B but that didnt really help anything.
Any suggestions?
Thanks,
Dan,
You've already established that sup A + sub B is an upper bound for the A + B. All that remains is to show that it's the least upper bound.
I guess that's what I am having trouble with. I tried assuming that there exists some other upper bound 'r' which is less than sup A + sup B, and then showing that this leads to a contradiction. No luck though :(
He isn't required to show that it is the least upper bound, only that it is an upper bound.
Yes, but he already showed this in the first post, my understanding was that he was curious to see why it's the least upper bound.
danago, if k is the supremum of A + B, then for any epsilon > 0, there's an element x in A + B satisfying |k - x| < epsilon. All you have to show is that sup A + sup B has this property.
If you want to prove that anyway, just note that [tex]\sup A - \frac{\epsilon}{2} < a \ \mbox{for} \ \exists a \ \mbox{and} \ \forall \epsilon > 0[/tex]. The same applies for b. See how to continue from here?
But his question was, "Why is it not the least upper bound?"
danago, the fact that you are asked to prove that [itex]sup A+B\le \sup A+ \sup B[/itex] does not necessarily imply they are not equal. Only that you are not asked to prove that.
Ok fair enough. So what I've done is sufficient to answer the question then?
Yes.
Alright thanks everyone :smile:
