How Can You Separate Salt and Pepper Without Physical Contact?
  • Thread starter Thread starter some_one
    Puzzle
The discussion revolves around the challenge of separating a mixture of salt and pepper without any physical contact. Participants explore various methods and theories related to this problem, including physical properties of the substances and creative approaches to separation.
  • Some participants assert that physical separation is impossible without touching the mixture.
  • Others suggest using static electricity as a method of separation, although this raises questions about whether it constitutes physical interaction.
  • One participant proposes using a centrifuge, arguing that salt is heavier than pepper, but acknowledges the difficulty of using it without physical contact.
  • Another participant describes an experiment where boiling water was used, claiming that the salt sank and the pepper floated, leading to separation.
  • There is a discussion about the melting points and densities of salt and pepper, with some participants questioning the feasibility of heating them to separate the components.
  • Several participants engage in a playful tone, questioning the rules of the challenge and suggesting alternative methods or clarifications.
Participants generally do not reach a consensus on the methods of separation, with multiple competing views and ongoing debate about the feasibility of suggested techniques.
Participants express uncertainty about the properties of salt and pepper, including their melting points and densities, which may affect the proposed methods of separation. The discussion also highlights the ambiguity of what constitutes "physical contact."
some_one
we mix one spoon of salt
and one spoon of pepper together
and mix them
how to separate them without touching the mixed salt and pepper
no physical touching aloud
If no physical touching allowed then we can't physically separate them.
Separating the salt and pepper pots is aloud?
like obama says
YES WE CAN
when do i need to post the answer to the puzzle?
Are the grains of equal size?
Let it mature a bit, let people come along with suggestions and questions.
we need to separate them without touching the mix physicly
the granes are equal in size
first clue
acctually it doesn't matter
Equal density?Same form?
Pepper and salt have different melting points ... is that possible?
different mass?
what is your method of separation?
put some heat on it and evaporate chillies (collect somewhere : flash -- no touching)
2) Use air force...
Pepper doesn't melt.
sounds impossible..
I am considering something 1400 deg C or over...
I thought pepper has lower melting point than salt
(don't know what kind of bonds it has ... )
yeee but pepper which origins from a plant when heated
comes in contact with the oxigen in the air
and gets burned
which is not aloud
Take a balloon and rub it on a wool sweater, then hold it right above the mixture.
biiiiingooooo
you are correct
rootX said:
sounds impossible..
:biggrin: Wouldn't that would be more along the lines of incineration?
That never happened in my chemistry class/course/book :shy:
I actually mixed a pinch of salt and of pepper with the intention of boiling the mixture. I figured the pepper would drift to the bottom of the water and the salt would diffuse. Then after boiling the salt would form a crust above the pepper. But as soon as I put the mixture in the water, the salt sank to the bottom and the pepper floated on top. Separate.
static electricity is the answer
Because electricity is not physical?
I have a better question, how do you separate a mix of salt and pepper using no energy?
OK, for future reference, it's 'allowed'. :wink:
Static electricity is still physical interaction for me. Anyways, with static electricity you grab pepper or salt?
pepper
How about a centrifuge? I figure that salt is heavier than pepper.
You can't have physical interaction, and getting the mix into a centrifuge without physically touching it would be pretty hard.
It most distinctly is not.
You could slip a solid object such as a piece of paper between the balloon and the mixture. No physical contact.
11K
