An electromagnetic induction question
The discussion centers on the relationship between the area of a secondary coil and the induced voltage across a resistor in an electromagnetic induction setup. According to Faraday's Law, induced electromotive force (emf) is proportional to the area of the coil; however, the presence of a soft iron core with high permeability (\u03bc) significantly influences the magnetic flux. Increasing the area of the secondary coil does not enhance the induced voltage because it also encloses some return flux that opposes the primary flux, resulting in a net decrease in flux. Thus, the effective area of the secondary coil remains unchanged despite its physical enlargement.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Knowledge of magnetic permeability (\u03bc) and its effects on magnetic flux
  • Familiarity with the concepts of primary and secondary coils in transformers
  • Basic principles of magnetic field lines and their behavior in conductive materials
  • Explore the implications of magnetic permeability in transformer design
  • Study the effects of coil geometry on electromagnetic induction
  • Learn about the role of core materials in enhancing magnetic flux
  • Investigate advanced applications of Faraday's Law in electrical engineering
Electrical engineers, physics students, and anyone interested in the principles of electromagnetic induction and transformer operation.
herich
There is a soft iron bar, with two coils wound at the two end. A current source is connected to the primary coil. A resistor is connected to the secondary coil.
So, the question is:
"Whether increasing the area of the secondary coil but keeping the area of the primary coil unchanged can increase the induced voltage across the resistor connected the secondary coil?"
My attempt:
Correct,
since according to Faraday's Law, induced emf is proportional to the area of the secondary coil.
But the answer is incorrect. Actually why? Thanks
The reason is that the iron core has such high permeability [tex]\mu[/tex] that most all the flux from the first coil is found in the core and virtually none is in the air. Increasing the 2nd coil's area therefore doesn't increase the flux enclosed. In fact, the flux in the 2nd coil decreases a little because its bigger area now encloses some of the return flux that exits the end of the rod and bends back into the end of the rod at the 1st coil. The field lines of the return flux point opposite to those in the core so the net flux in coil 2 drops as its area increases.
I see. That means however the secondary coil 's area change, B-field only exists along the iron core. So, the "effective" area of the area of the secondary coil is still the same. Thanks!
  • · Replies 34 ·
