Proof of a limit of a cubic like sequence.
The discussion revolves around proving the limit of the sequence (4n^(3)+3n)/(n^(3)-6) as n approaches infinity, focusing on the use of epsilon-delta definitions and various methods of proof. Participants explore different approaches to establish the limit and question the reasoning behind certain techniques.
  • One participant presents a book's solution involving upper bounds and questions why they are necessary, suggesting that a lower bound could suffice.
  • Another participant simplifies the limit proof by arguing that as n approaches infinity, the dominant terms in the numerator and denominator can be used to show the limit is 4.
  • A different participant cautions against cancelling infinities without justification and proposes dividing by the highest power of n to rigorously show the limit.
  • One participant expresses a desire to understand the formal epsilon-delta approach as used in real analysis.
  • Another participant suggests using the same method of dividing by the highest power of n as a valid approach to prove the limit.
  • One participant mentions a restriction on using L'Hôpital's rule, emphasizing the need to adhere to fundamental definitions of limits in their self-study of real analysis.
Participants express differing opinions on the necessity of upper versus lower bounds in limit proofs, with no consensus reached on the best approach. There is also a divergence in methods, with some favoring a more formal epsilon-delta approach while others prefer simplifications based on dominant terms.
Participants highlight various assumptions and methods, including the reliance on the highest power of n in both the numerator and denominator, and the implications of using epsilon-delta definitions. The discussion reflects a range of mathematical rigor and approaches to limit proofs.
Readers interested in limit proofs, epsilon-delta definitions, and various mathematical approaches to sequences may find this discussion beneficial.
torquerotates
Now this is an example in my book that I don't really understand. It says prove that the limit of (4n^(3)+3n)/(n^(3)-6))=4 as n goes to infinity.
Basically the definition of a limit of a sequence as n->infinity is as follows.
Lim{a}=L
For any epsilion>0 there is a N>0 such that n>N=> |{a}-L|<epsilion
So here's the book's solution. I just don't know why they found upper bounds.
|(4n^(3)+3n)/(n^(3)-6) - 4|=|(3n+4)/(n^(3)-6)|<epslion
but if n>or=2, (3n+4)/(n^(3)-6)<epslion.
(3n+24)<or =30n
& (n^(3)-6)>or =(1/2)n^(3)
So, (3n+4)/(n^(3)-6)<or= (30n)/( (1/2)n^(3))<epsion
=> 60/n^(2)<epslion
=> (60/epslion)^(-1/2)<n
so this implies that we make N=max{2, (60/epslion)^(-1/2)}
Now here's my much more simplistic solution.
I never found a reason why they used an upper bound. Wouldn't a lower bound work just as well?
(3n+4)/(n^(3)-6)<epslion. { still given that n>or=2}
n/(n^(2)) <(3n+4)/(n^(3)-6)<epslion. Now I chose the denominator,n^2, arbitaritly just to make just sure that the denominator becomes smaller.
So solving, 1/epslion<n. This implies that we make N=max{2, 1/epsilion}.
See how simple this is. I didn't even use equal to or greater than/ less than. I just used a straightforward inequality. But is it correct? I have no clue why the book did it with upper bounds.
(4 * oo^3 + 3*oo)/(oo^3-6)) = 4
(4 * oo^3)/(oo^3)
4 = 4
I don't see what would be wrong with just showing that kn^3/n^3 for all n is k, and that n^3 + n = n^3 as n approaches infinity.
I could be wrong though.
I'm not sure you can justify cancelling infinities like that. More rigorous is to divide by both numerator and denominator by the highest power of n:
[tex]\frac{4n^3+ 3n}{n^3- 6}= \frac{4+ \frac{3}{n^2}}{1- \frac{6}{n^3}}[/tex]
Since both 3/n2 and 6/n3[/sub] go to 0 as n goes to infinity, the limit is 4/1= 4.
But I'm trying to understand it from a formal approach using epslion and a bound as they do in real analysis.
For proving this limit I would use the same method as Hall, I would divide each term in the numerator and denominator by the highest power of x that occurs in the denominator, namely, n3. Just like he did.
You must remember that [tex]lim_{x \rightarrow\pm \infty} \frac{1}{x} = 0[/tex] etc, and voila, you have limit = 4
Why can't you try L'Hopital's rule, btw?
I'm not allowed to do that because I'm self studying real analysis. I need to prove things from the most fundamental steps. I have to use the definition of a limit. Which is, for a sequence,
Lim{a}=L as n-> infinity means,
  • · Replies 16 ·
  • · Replies 16 ·
