Creating Accurate Low-Cost Circuit to Convert 120VAC Current to Voltage
The discussion revolves around designing a low-cost circuit to convert 120VAC current into a voltage signal. Participants explore various methods and components, including shunt resistors, op-amps, current transformers, and Hall Effect sensors, while addressing challenges related to parts count, accuracy, and safety in the circuit design.
  • One participant describes a circuit design using a shunt resistor and op-amps but expresses concerns about parts count and voltage pin limitations.
  • Another participant suggests using a current transformer as a non-contact solution, raising questions about inductance, orientation, and calibration.
  • A suggestion is made to use a current clamp meter or probe for measuring AC current, with links to commercial products.
  • One participant proposes a Hall Effect sensor as an alternative, noting its suitability for specific current ranges and suggesting purchasing a clamp meter for occasional measurements.
  • A participant recommends placing the shunt on the low side of the load to reduce the signal within the op-amps' input range, emphasizing safety and isolation techniques.
Participants present multiple competing views on the best approach to measuring current, with no consensus reached on a single solution. Various methods, including shunt resistors, current transformers, and Hall Effect sensors, are discussed, each with its own advantages and challenges.
Participants express concerns about the accuracy and safety of different methods, particularly regarding the voltage levels and the need for isolation in the circuit design. There are also unresolved questions about the calibration and installation of suggested components.
J_Sieg
Hi,
I'm looking to create a simple circuit to convert current on a nominal 120VAC line into a voltage. I have a few designs but am having some difficulty keeping parts count low and maintaining accuracy.
What I have is as follows:
- I am using a shunt resistor, outputting 1mV per ampere of current (0-15mV total).
- I take the output from the shunt resistor (120VAC +/- 15mV) and use it as an input for two op-amps (running single supply [+3V] differential amplification).
- From the op-amps, I take the output and make it positive only via some diodes, then through a filtering capacitor.
- This gives me a voltage proportional to the current, or should..
The problems I am having have to deal with two things...
First is parts count. That is a hugely inefficient way to do things, having two entire amplification circuits, even with a dual op amp. I am wondering if there is a way to do this with a single amp.
Second, pin voltage is exceeded, as even though the voltage differential is 15mV max, it is on a 120V offset.
Do any of you have ideas on how to simplify this circuit? Op amps that might handle 120V on a pin, preferably at a low cost? That also take monopolar power? I tried a voltage divider, but if I divide the offset, I also divide the signal and lower my read resolution.
Thanks!
Two words: Current Transformer.
That would be nice, and non-contact, too...
But how could I get 3V for 15A? What is the inductance of the primary wire? Orientation of the other coil? How do I calibrate it?
edit: forgot to specify, it would be ideal if this was non-disruptive (ie, could be installed as either a pass-through device or purely inductive, with no need for circuit disconnection/disassembly to install the unit).
Depending on how much current you're trying to measure, maybe a Hall Effect sensor? CUI makes some (sold at DigiKey), but it starts around 3A:
http://www.cui.com/srchresults.asp?catky=560054&subcatky=731029&subcatky2=825892
But if you only want to take one or two-off measurements (and you're not, say, designing instrumentation or making a long-term current monitor / logger), buy yourself a current clamp as berkeman suggests. Aside from Fluke, Extech and Meterman make more affordable (yet high-quality) clamps. If you want to splurge, get the ones that do AC AND DC current measurement (the cheaper ones only do AC--which might be all you need).
Why don't you put the shunt on the low side of the load? That will give you a much smaller signal within your op-amps input range.
that Fluke clamp-on Berkeman suggests is a godsend to troubleshooters. I scored one at a flea matket.
great suggestion !
you can put your shunt in the neutral wire but place the whole works in an insulated box with no exposed metal.
Reason: By Murphy's law, second time you use it you'll plug it into a recetpacle that was wired backwards, hot and neutral reversed, and the smoke will be let out of your opamps.
google "high side current sense" there's several other techniques. Isolating opamps is one of them.
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 78 ·
