Register to reply
Homework question on: Calculating net force and resistance forces, calculate work.
by Jacko_065560
Tags: force, magnitude, movement, newton, work
Share this thread:
Jacko_065560
#1
Aug18-08, 05:18 AM
P: 3
Hi all, I am having difficulty in understanding this basic phyics relating to force, work,and movement, and I am struggling to do these questions. I would appreciate any help.
The following information was provided and then three questions followed.
A boy drags a box by a rope across a level floor. The box is moving at a constant velocity of 1.6ms-1 west. The boy applies a constant force of 120N along the rope. The rope makes an angle of 30 degrees to the horizontal.
Q1) What is the magnitude of the net force acting on the box?
Q2) Calculate the magnitude of the resistance forces acting on the box. Justify your answer.
Q3) How much work does the boy do against the resistance forces when he drags the box a distance of 5.0m?
I figure that I need to use "F = ma" somewhere, along with the "Work = Fs." I am unsure what else I would use because this is the main problem I am having, applying the equations and rules.
So far, I have managed to do the following workings in an attempt to complete the questions:
1) Using Trig, I calculated that the horizontal line of force acting on box in west direction is equal to 120NCos30 = 103.92N West. Is this the only working I need to do??
2) I think I need to connect the velocity with the 103.92N of horizontal force but I cant think of how to... I have looked through my notes and I guess that Newton's third law can be applied, but I am quite unsure....
3) Well "W = Fs" would be used, with W being unknown, the forces from questions 1 & 2 being substituted for the Net Force F and the displacement, s, would be 5m.
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
danago
#2
Aug18-08, 05:42 AM
PF Gold
P: 1,125
Unless ive missed something, Q1 ands Q2 seem to be the exact same questions.
Consider the acceleration of the box. Then relate this to the net force, using newton's second law. (note that the question asks for the magnitude of the net force).
EDIT: Was question 1 supposed to be the force due to the rope?
Jacko_065560
#3
Aug18-08, 05:56 AM
P: 3
My apologies, I have edited Q2 as above, "Calculate the magnitude of the resistance forces acting on the box. Justify your answer"
RE: EDIT, Question 1 is about the net force, so I take it to be the force in a westerly, horizontal direction and any resistance forces. The rope is at 30 degrees from horizontal so i calculated the horizontal force to be 103.9N (using 120cosine30).
So the acceleration is 0ms-2, because it is moving at a constant velocity of 1.6ms-1
F = ma
Net force = mass x 0...
Net force is 0?
aamphys
#4
Aug19-08, 02:02 AM
P: 6
the answer to the second question is 0 N because its travelling at a constant speed
C. Hollmann
#5
Aug19-08, 11:00 AM
P: 2
Quote Quote by Jacko_065560 View Post
Yes, that is all the math you need for this one... But there is no acceleration, therefore no net force. The answer is zero!
Again, you know that net force is zero, due to zero acceleration. This means the resistive force exactly balances the force applied through the rope. In order to arrive at zero net force, the resistive force must have the same magnitude, but opposite direction as your calculated force.
Yup!
CH
Jacko_065560
#6
Aug21-08, 04:53 AM
P: 3
thanks alot to everyone who helped! i understand now!
Register to reply
Related Discussions
Air resistance, how to calculate it? General Physics 9
Force applied: calculating increase in temperature (work mostly done, need help!) Introductory Physics Homework 1
Calculating Work Done by Variable Force Introductory Physics Homework 4
Force and work homework problem Introductory Physics Homework 1
Resistance force and work Introductory Physics Homework 1
