Solve this Math Problem: Find Last 2/3 Digits of 3^3^3^3
  • Thread starter Thread starter ilml
The discussion centers on finding the last two and three digits of the expression 3^3^3^3. The last two digits are determined to be 27 through modular arithmetic and cyclicity of digits. The last three digits can be calculated using similar methods, specifically modular exponentiation. The key concepts involved include identifying recurrence patterns and applying modular arithmetic to simplify calculations.
  • Understanding of modular arithmetic
  • Familiarity with cyclicity of digits in powers
  • Knowledge of exponentiation techniques
  • Basic principles of number theory
  • Learn about modular exponentiation techniques
  • Explore recurrence patterns in number theory
  • Study the properties of cyclicity in powers of integers
  • Investigate advanced modular arithmetic applications
Mathematicians, students studying number theory, and anyone interested in solving complex exponentiation problems.
ilml
Hello, I was randomly browsing sites and I came upon this math question which I am stuck on (and desperately want to solve!): Find the last two digits of 3^3^3^3. Can you find the last three digits?
I'm stuck on this problem because I really don't know where to begin. I figure that you need to find a pattern or period of some sort, but the numbers grow too fast and therefore there aren't that many readily available samples. Any help is appreciated! THANKS!
Instead of tackling the original problem, you should try first to find the answer to the following problem:
What is the last digit of the tower?
Note the following:
We have the recurrence pattern for the last digit:
3->3
3*3->9
3*3*3->7
3*3*3*3->1
And back again!
Hence, we have a "4-periodicity" for the last digit, and you should be able to solve the problem.
Clearly, you may grit your teeth together and find similar reccurrence patterns for the 2 last digits and 3 last digits problem.
However, I would believe that such recurrence patterns are well known in number theory; since I'm ignorant of that field, I can only suggest that you post your question in the "Number Theory" subforum.
To solve this problem, we can use the concept of modular arithmetic. The last two digits of a number can be found by dividing the number by 100 and taking the remainder.
First, let's simplify the expression by finding the last two digits of 3^3 and 3^3^3.
3^3 = 27, so the last two digits are 27 % 100 = 27.
3^3^3 = 27^3 = 19683, so the last two digits are 19683 % 100 = 83.
Now, we can use this information to find the last two digits of 3^3^3^3.
3^3^3^3 = 3^19683.
We can use the concept of modular exponentiation to simplify this expression.
3^n % 100 = (3 % 100)^n % 100
So, we can rewrite 3^19683 as (3 % 100)^19683 % 100.
Now, we can substitute the values we found earlier for 3^3 and 3^3^3.
3^19683 = (27)^83 % 100.
Using the same method as before, we can simplify this to (27 % 100)^83 % 100 = 83^83 % 100.
To find the last two digits, we can use the cyclicity of digits.
The last two digits of powers of 83 follow a pattern of 83, 89, 47, 41, 43, 49, 87, 81, 83...
So, the last two digits of 83^83 will be the same as the last two digits of 83^(83 % 8) = 83^3 = 27.
Therefore, the last two digits of 3^3^3^3 are 27.
Similarly, to find the last three digits, we can use the same method but instead find the last three digits of 3^3^3^3.
3^3^3^3 = 3^19683.
Using the concept of modular exponentiation, we can rewrite this as (3 % 1000)^19683 % 1000.
Substituting the values we found earlier, we get (27 % 1000)^83 % 1000
  • · Replies 26 ·
