Calculating KWH Generated by a Water Turbine?
  • Context: Undergrad
  • Thread starter Thread starter arranged
    Wattage
The discussion revolves around calculating the energy produced by a water turbine based on the volume of water falling through a specific height. Participants explore the relationship between gravitational potential energy, power, and energy conversion, while addressing the calculations involved in determining kilowatt-hours (KWH) generated by the turbine.
  • One participant outlines a method for calculating power generated by a water turbine using height, radius, and velocity, but seeks clarification on converting wattage to KWH.
  • Another participant corrects the first by stating that KWH is a unit of energy, not power, and suggests using gravitational potential energy for a simpler calculation.
  • A participant acknowledges the suggestion of using potential energy and expresses confidence in their wattage calculation, seeking confirmation from others.
  • Another participant challenges the wattage calculation, stating it incorrectly equates kinetic energy to power and questions the volumetric flow rate calculation.
  • A final participant suggests searching for online hydro power calculators that may provide additional information and details about various factors affecting turbine efficiency.
Participants express differing views on the calculations involved, with some agreeing on the use of gravitational potential energy while others contest the initial wattage calculation and the method of determining volumetric flow rate. The discussion remains unresolved regarding the correctness of the initial calculations.
Participants highlight potential misunderstandings regarding the definitions of power and energy, as well as the calculations for volumetric flow rate and mass flow rate, which may depend on specific assumptions about the system being analyzed.
arranged
I'm attempting to calculate the amount of power (in KWH) produced by a water turbine based on x litres of water falling x metres vertically through a tube of x cm diameter
So far I've managed the following:
H = height (distance fallen) (m)
Time = Secs
R = Radius of the pipe (m)
Velocity (m/s) = (2 x H x G) ^ 0.5
Volume / Sec = Velocity x Time x Pi x R^2
mass (kg) / Sec = (Volume / sec) x 1000
Energy = (Mass x Velocity^2)/2 = wattage generated
My questions is... how do i convert this wattage generated in KWH generated?
Once I have this am i correct in thinking I can do:
(KWH generated / 3600) * (time taken for x litres of water to fall through the pipe).
To calculate the KWH generated by the x litres of water falling?
Any help / guidance anyone could give me would be greatly appreciated. - As you can (maybe) tell I'm by no means a physics graduate but i do have a basic understanding.
Any help anyone could give me would be greatly appreciated.
Many Thanks
P.s For the purposes of this I'm happy to work with a turbine having 100% efficiency.
Power isn't measured in kWh; that's a unit of energy.
Energy (in Watt-hours) = power (in Watts) * time (in hours).
So, if your turbine produces 100kW (power) constantly for 3 hours (time), you will have produced 300kWh of energy.
The short way of finding out the amount of energy available in your example would just be to use:
Gravitational potential energy = (mass of water)*(vertical distance travelled)*g
Ok?
thats a good point, i never thought of working it out with PE, that would have made it much simpler.
Thanks for your comments they are extremely useful.
Did u happen to look at my wattage calculation? I'm fairly confident it's correct but would be useful if someone could confirm it.
Thanks again for your help.
Well your 'wattage calculation' is wrong, because (mass*velocity^2)/2 equals kinetic energy, not power.
Power is the rate of consumption/production of energy:
Power = energy / time
Also, your volumetric flow rate calculation is incorrect. Volumetric flow rate equals flow velocity multiplied by the cross-sectional area of the pipe. I don't know why you've multiplied this by time. Then, mass flow rate is just volume flow rate multiplied by density; in this instance it's water so 1 litre per second is one kilogram per second.
arranged-
Do a search for "hydro power calculator". You'll find many online and several will go into the details...frictional losses, head pressure, etc...some theoretical and some real-world.
There's loooooots of info out there online and sometimes the hardest part of finding it is the phrasing of the search term.
Toymkr
  • · Replies 18 ·
  • · Replies 35 ·
17K
