Thread Closed
simple solution?
Share Thread
Aug20-08, 12:13 PM   #1
simple solution?
just looking for a quick solution for my equation, seems like my head is just working the wrong way coz I know it's not a hard one:
a2 + a2 = (a + 1)2
a = ?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Aug20-08, 12:29 PM   #2
Recognitions:
Homework Helper Homework Help
a2+a2=2a2
expand the right side and then simplify.
Aug20-08, 12:37 PM   #3
i don't believe that (a + 1)(a + 1) is 2a2
shouldn't that give a2 + 2a +1 ??
Aug20-08, 12:41 PM   #4
simple solution?
[tex] a^{2} + a^{2} = (a+1)^{2} [/tex] simplifies to [tex] a^{2} + a^{2} = a^{2} + 2a + 1 [/tex] which when you move everything over to one side becomes [tex] a^{2} - 2a - 1 = 0[/tex] which is easy enough to solve. Not sure how rock.freak got what he did.
Aug20-08, 01:12 PM   #5
Quote by rock.freak667 View Post
a2+a2=2a2
I'm sure he was simplifying the left side (how much simpler can it be?). Then he said expand the RHS and rearrange to solve.
Aug20-08, 01:22 PM   #6
solved it now
a2 + a2 = a2 + 2a + 1
simplified it to a quadraticequation
0 = -a2 + 2a + 1
a1 = 1 + sq.root of 2
a2 = 1 - sq.root of 2
a2 is negative therefore a1 is the right answer
which gives a = 2,41
Aug20-08, 01:29 PM   #7
Quote by eskil View Post
solved it now
0 = -a2 + 2a + 1
Why can't a be negative?
On the LHS you had [tex] a^{2} + a^{2} = (1 - \sqrt{2})^{2} + (1 - \sqrt{2})^{2} = 1 - 2 \sqrt{2} + 2 + 1 - 2 \sqrt{2} + 2 = 6 - 4 \sqrt{2} [/tex]
However on the RHS you had [tex] (a+1)^{2} = (1 - \sqrt{2} + 1)^{2} = (2 - \sqrt{2})^{2} = 4 - 4 \sqrt{2} + 2 = 6 - 4 \sqrt{2} [/tex]
Note also that the "simpler" way to do this would be to rewrite it as
[tex] 2a^{2} = (a+1)^{2} \Rightarrow \sqrt{2} |a| = |a + 1| [/tex] and examine the appropriate regions to get rid of | |.
Aug20-08, 03:51 PM   #8
The reason why it cannot be negative is that the origin of the problem was to determine the length of all sides of a likesided triangle thus can't be negative.
I still think that using the quadratic equation is the simplest way of solving it.
Thread Closed
Similar discussions for: simple solution?
Thread Forum Replies
Solution of a simple Differential Equation Differential Equations 5
Solution to Simple Matrix Equation General Math 1
Simple solution of FLT? Linear & Abstract Algebra 28
Need solution tto simple problem Introductory Physics Homework 4
simple harmonic oscillator general solution Classical Physics 5
