Projectile Motion, find max height, TWO POSSIBLE ANSWERS?
The problem involves determining the maximum height of a projectile launched with an initial velocity of 30 m/s, covering a horizontal range of 45m. The original poster mentions two possible maximum heights: 2.96m and 43.0m, expressing confusion about how to arrive at the second height.
  • Participants discuss the possibility of two maximum heights based on the wording of the problem and the conditions of the launch. The original poster attempts to find the second height by considering the projectile's launch angle and horizontal motion, while others question the assumptions about the launch conditions.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some suggest that the two heights could arise from different launch angles, while others express uncertainty about the implications of the problem's wording. Guidance has been offered regarding the equations and concepts involved, but no consensus has been reached on the correct approach to find the second maximum height.
There is ambiguity in the problem regarding whether the projectile was launched from the ground or from a height, which influences the interpretation of the two maximum heights. Participants are also grappling with the implications of the projectile's initial velocity and the relationship between launch angle and range.
iceman99
A projectile is launched with an inital velocity of 30 m/s so that it covers a horizontal range of 45m. Determine the maximum height reached by the projectile. (There are two answers)
I know the answers are 2.96m and 43.0m. but I only know how to find the first. :(
To be honest I have been working on this problem for a good 30 minutes. I found the 2.96m pretty easily, but its the 43m that has me stumped. I really have no idea what equations I could use to find the second maximum height of 43m.
The only thing that I can see to solve the second part of the problem is that the projectile was thrown horizontally at 30 m/s from a building, landing 45m away. However when I put that theory to paper I came up with the height only being roughly 11.025m tall.
By this:
45m=30m/s times t
I found that t would equal 1.5s, after which i plugged that into the equation y=1/2gt^2 ending with y equaling 11.025m. But that is not right.
I tihnk the trick to this problem is in the wording of the problem but I just can't see it.
It would be greatly appreciated if I could have some help, this is for an AP physics summer assignment. I'm close to dropping this class because of how angry this is getting me. I would be grateful for any advice.
This is the entire question? If so, I don't think there can be two maximum heights for one parabolic motion.
Just tried another thing.
I set out to find the angle of the projectile when it landed setting my right triangle to:
Vx=30m/s
Vy=14.7m/s found by Vy=9.8m/s^2 x 1.5s Vy-14.7
Found the angle to be 26.10degrees
Making a new triangle with 26.10 as my theta and 45m as its adjacent length
Solving for the opposite length was found to be 22.045m darn...
I think something is just majorly wrong in my concepts for this to work, but oh well I was desprate for an answer.
Yeah that's the whole problem
Yeah I think that from the wording it means that it was launched from the ground at 30m/s which the maximum height was 2.96m. But because the question doesn't indicate that it wasnt launched from a building, it could be where the 43m comes from.
For every projectile launched at a fixed velocity and hitting a fixed target there are two angles in which it can do it. There will be one large on, and one small one. You found the small one, now you just need to find the other.
Pay careful to the equations that you use. The equation y = .5gt^2 you used, what does the "t^2" tell you about the solution of that equation?
Physics should not be hated, it should be enjoyed!
Um...I had no idea about that. How could I find the larger angle?
Sure there are. If you launch it at 45 degrees it will reach a maximum range. If the given range is less than that then there is one angle greater than 45 degrees and one angle less than 45 degrees that will achieve that range.
OK, but how could I find the max height of the larger angle? Wouldn't the velocity need to be changed or am I wrong about that too?
How did you find the smaller angle? You should be able to find the larger one the same way.
R=(Vo^2sin(2theta))/g i found theta to be 14.607degrees...
Oh I got it
I can't really believe I was that dumb. Sorry, thanks a lot for the help
We have all done the same thing at one point. :cool:
  • · Replies 18 ·
28K
