How Does Earth's Rotation Affect Acceleration at the Equator?
The discussion revolves around calculating the acceleration of a body at rest on the Earth's equator due to the Earth's rotation. The problem involves concepts from physics related to gravitational forces and centripetal acceleration.
  • Mixed
  • Participants explore the relationship between gravitational acceleration and centripetal acceleration, questioning the use of approximations for gravitational acceleration (g). Some suggest focusing on centripetal acceleration as the primary concern for the problem.
Participants are actively discussing the nuances of the calculations, with some pointing out potential errors in the original poster's approach. There is recognition of the need for precision in measurements and the implications of using different values for gravitational acceleration. The conversation is exploring various interpretations of the problem statement.
There is ambiguity in the problem statement regarding the object's state of rest relative to the Earth's rotation, leading to discussions about how to properly frame the calculations. Participants note that local variations in gravitational acceleration may affect the results.
Benzoate
A body is at rest at a location on the Earth's equator. Find its acceleration due to the Earth's rotations. [Take the Earth's radius at the equator to be 6400 km.]
Possible relevant equations: a=(dv/dt)*t + (v^2/rho)*n, n is the unit normal vector., F= M*m*G/(R^2(earth))
If the body is at rest , then the velocity of the body must be zero. F=M*m*G/(R^2(earth))=> m*(a+g)= M*m*G/(R^2(earth)) => a+g= MG/(R^2(earth)) , M being the mass of the earth. Therefore a= MG/(R^2(earth))-g = (6.0e24)*((6.6e-11))/((6.4e6 m)^2) - 9.8 = -.0294 m/s^2.
The actually answer is .034 m/s^2. What is wrong with my calculations?
One thing that's going to give you trouble is that none of your data is precise enough to get the answer accurately to three decimal places (you are plainly in the right neighborhood, but you couldn't properly give the result to better precision than 0.03 m/sec^2). You should use at least three significant figures for G and the Earth measurements...
But there's a separate problem -- where is that 9.8 coming from and is it really '9.8'? You're actually making the problem harder than it needs to be. Since the object is at rest right on the Equator, you only need to work out the centripetal acceleration
[tex]a_c = \frac{v^2}{R_E} = \omega ^2 \cdot R_E[/tex]
It will probably be easier to deal with using the Earth's equatorial radius and its angular speed, [tex]\omega = \frac{2 \cdot \pi}{T}[/tex]. Note: you'll want to use the length of the sidereal day, the actual period of Earth's rotation (23 hrs. 56 min. 4.091 sec.), rather than the solar day of 24 hours.
Whoa, whoa. M_earth*G/R_earth^2 IS g. What you are computing there is the roundoff between the exact value of g and the approximation g=9.8m/s^2. The acceleration due to the rotation of the Earth is the centripetal acceleration v^2/r. Compute that.
You are correct, though there is a small subtlety that comes up if you go to look up values. The relation that you give is what is generally taken as g and is where the number 9.807 m/sec^2 comes from. But if you look up the measured value of Earth's gravitational acceleration (at mean sea level), you find something more like 9.78 m/sec^2 (what I believe some people refer to as go). The difference is largely due to what Benzoate is being asked to compute.
In fact, local values of "g" vary about 9.78 by a few hundredths of a m/sec^2 over the Earth's surface at different latitudes and altitudes -- to say nothing of "anomalies" due to variations in the planet's density (the so-called "mass concentrations and deficits": the relics of Earth's formation from planetesimals).
Right, right. But what Benzoate is asked to compute is the acceleration due the the Earth's rotation. That's pure v^2/r. Nothing to due with estimated values of g or planetesimals or anything. Benzoate is just doing the wrong calculation.
So when an object at rest near the surface of the earth, I should act as if the object is rotating around the Earth instead of the Earth rotating while the object is motionless near the Earth's equator?
If the object is not rotating with the Earth then there is no acceleration due to the Earth's rotation, is there??
... Benzoate is just doing the wrong calculation.
No argument there. I was pointing out the hazard of using "g" too casually in a problem, as was done in the OP. As you point out, the result in the first post should be exactly zero.
Ah, the problem is ambiguously stated: they mean that the object is at rest with respect to the surface of the rotating Earth, which mean it is revolving around the center of the Earth once a sidereal day.
