Star Delta Transformation Proof
The discussion revolves around the proof of the star-delta (or delta-Y) transformation in electrical circuits, specifically focusing on the effective resistance between two vertices in both configurations. Participants explore the implications of connected and unconnected resistors in the context of circuit analysis.
  • Homework-related
  • One participant presents a proof for the star-delta transformation, questioning the treatment of unconnected resistors in the circuit.
  • Another participant points out a potential issue with the connection in the second diagram, suggesting it should connect between 'a' and 'c' instead of directly to 'a'.
  • A participant clarifies that if a resistor is not connected, it behaves like an open circuit, implying it can be ignored in calculations.
  • Concerns are raised about the validity of the proof, particularly regarding the assumption that the transformation holds true for circuits with arbitrary terminal connections.
  • One participant asserts that the effective resistance between nodes 'a' and 'c' in the star configuration is still given by the sum of the resistances Ra and Rc, regardless of the presence of Rb.
  • Another participant discusses the calculation of total resistance in the presence of an additional resistor, emphasizing that while Rac remains the same, the total resistance of the circuit changes.
  • There is mention of the applicability of high school physics principles to establish the transformation, despite it not being part of the syllabus.
  • Clarifications are provided regarding the effects of Rb on other resistance calculations, such as Rab and Rbc.
Participants express differing views on the treatment of unconnected resistors and the validity of the proof. While some agree on the effective resistance calculations, others question the assumptions made in the proof, indicating that the discussion remains unresolved.
There are unresolved assumptions regarding the behavior of unconnected resistors and the conditions under which the star-delta transformation is valid, particularly in relation to linear versus non-linear components.
GPhab
I've come across a proof for star-delta transformation which goes like this.(Refer to the diagram for notation. Pardon me for my bad drawing skills.)
In the delta, he found the effective resistance between two vertices ( say a and c, which can found easily). Then he found the effective resistance between the same two vertices (a and c)
in the star. According to him Rac in the star(which denotes the resistance between a and c) is equal to Ra + Rc. What about Rb? It might not be connected here but it may in a circuit. It is like this(refer to second attachment). The resistance about ac in the left diagram of second attachment is 2[tex]\Omega[/tex](drawing analogy from the "faulty" proof) but link it to another circuit (shown in right diagram), the resistance about ac is different. So just because it isn't connected, it doesn't mean that you can ignore it. Here's the surprise. The proof gives the CORRECT EQUATIONS. Work it out. You'll end up with the right thing!Can anybody make things clear for me?
Did I not follow any guidelines? How come nobody is replying?
I wonder why the third line in your second diagram is connected directly to 'a' and not between 'a' and 'c'.
you need to be more patient. i hadn't seen this post before this moment. give it a couple of days and if no one responds by 48 hours, then you have good reason to inquire.
okay, first of all, this is normally called a "delta-Y transformation" or, less often, a "[itex]\pi[/itex]-T transformation". never heard of the "Y" called a "star" in this context.
GPhab said:
... Rac in the star(which denotes the resistance between a and c) is equal to Ra + Rc. What about Rb? It might not be connected here but it may in a circuit.
if it's not connected to anything, no current flows through it. if no current flows through it, the behavior is no different than an open circuit (a.k.a. nothing).
if the impedance (or any two-terminal part) isn't connected on one end, how does it make any difference if it's connected (or not) on the other end?
this "proof" you see is standard in any first-semester electrical engineering text (and i can go through it in detail if you want). the result is true, but i have never been satisfied with the proof because usually it requires assuming at the outset that the transformation of the circuit with all three terminals connected is equivalent to the transformation of the circuit when any arbitrary pair of terminals are connected. it turns out to be true for linear components (resistors or complex impedances) where the super-position property is valid (and that fact has to be established), but is not true for non-linear devices.
Since this is homework/coursework, I moved it from General Physics to Homework Help.
Can it be established using the principles we learn in high school physics? (Actually this "Y-delta" transformation is not in our syllabus, but I picked it up so that I could get a convincing solution for some problems like a cube of resistors-It turned out to be one heck of a workout though. :smile:)
I haven't received a convincing reply for the contradiction we are facing in circuit2.
In the second image, Rac will still be given by Ra+Rc.
The right hand circuit has an extra resistor (R1) and as such the overall resistance of the circuit will be calculated using a different equation (this doesn't have any effect on Rac only on the TOTAL resistance of the circuit). As the resistor R1 in in parallel with the Rac this would be calculated either using the product over sum rule:
[tex]R_{T}=\frac{R_{ac}\times R_{1}}{R_{ac}+R_{1}}[/tex]
or the equation:
[tex]\frac{1}{R_{T}}=\frac{1}{R_{ac}}+\frac{1}{R_{1}}[/tex]
I have attached a picture that will hopefully clarify my point a little further.
I think it is important to note that the circuits shown in the second image are in face connected in Star formation, if it were in Delta then there would only be a single Resistor connecting node A to node C (using the notation from your first diagram this would be R2.)
In addition to what rjb was saying in relation to Rb when finding the value for Rac, Rb has no effect but obviously when you come to find the value for Rab and Rbc then Rb comes into effect.
again using notation from your first diagram:
[tex]R_{1}=R_{ab}=R_{a}+R_{b}[/tex]
[tex]R_{3}=R_{bc}=R_{b}+R_{c}[/tex]
I hope this helps
Ram
  • · Replies 43 ·
17K
  • · Replies 20 ·
