Dimension, Image, Kernels etc - Linear Algebra stuff
The discussion revolves around a linear transformation T defined on the vector space of polynomials, specifically examining its kernel and range dimensions based on the number of distinct points and polynomial degree. The problem is situated within the context of linear algebra.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between the dimensions of the kernel and image of the transformation T, considering cases where the number of points exceeds the polynomial degree and vice versa. Questions arise regarding the implications of distinct points and the nature of the kernel.
There is an active exploration of different cases regarding the dimensions of the kernel and image, with some participants providing insights based on specific examples. Clarifications about the distinctness of points and the implications for the kernel's dimension are being discussed, but no consensus has been reached.
Participants note the importance of the distinctness of points in the transformation T and the implications this has on the kernel's dimension, particularly in cases where the number of points exceeds the polynomial degree.
kehler
Does linear algebra go in this thread??
Anyway,
Let n be an integer at least 1, and x1,...,xn be distinct points in R. For any integer m>=1, let P denote the vector space of polynomials of degree at most m. Define a linear transformation T:P->R^n by
[f(x1)]
[f(x2)]
T(f)= [ . ] <--- (That's meant to be one big bracket)
[f(xn)]
What is the dimension of the kernel of T? What is the dimension of the range of T? (your answer will depend on m and n)
dim V = dim I am + dim ker
Well I've considered the case when n>m. In this case, dim V= m+1 and dim ker = 0 as it's not possible for any polynomial of degree m+1 to have more than m roots. So I find that dim I am = m+1.
Now for m>=n, I don't seem to be getting anywhere. Is the dimension of the kernel m-1 cos there can be m-1 roots?
Any help would be really appreciated :)
Argh it messed up my bracket.
Well T(f) is meant to be
[f(x1)]
[f(x2)]
[f(x3)] <- it's meant to be a single long bracket extending downwards
[f(xn)]
So T(f) maps f into (f(x1), f(x2), f(x3)...)?
Okay, f is in the kernel of T if and only if f(x1)= 0, f(x2)= 0, ...
(y1, y2, y3, ...) is in the image of T if and only if there exist a polynomial f such that f(x1)= y1) f(x2)= y2, ...
Yea that's right. So when m>n, the polynomial will have m roots. In this case is the dimension of the kernel 1 and the dimension of the image m? I'm kinda confuse about how I can tell what the dimension is.
(The dimension just means the number of vectors in the basis)
I'd like to clarify something here. Does the transformation T operate only on (x1,x2...xn) where all the xi's are distinct? Suppose for eg. m=2, then f(x) has two roots and the vectors in ker(T) are of the form (x1,x2,x1,x1...) <-any permutation of x1 and x2, which grows to an exponentially large number.
The transformation T operates on polynomials. I'm going to assume that x1, x2, etc. are distinct.
For example, suppose [itex]x_1= 0[/itex], [itex]x_2= 1[/itex] and m= 2 so P is the vector space of polynomials of order at most 2.
Then T(p(x))= (p(0), p(1)). The kernel is the subspace of all such polynomials such that p(0)= 0, p(1)= 0. Since p(x)= a+ bx+ cx2, p(0)= a= 0 and p(1)= b+ c= 0. Since c= -b, we are free to choose b and then a= 0, c= -b so the kernel has dimension 1. Since P itself has dimension 3, it follows that the image of T has dimension 2.
More generally, P has dimension m+ 1. Setting P(x1)= 0, ..., P(xn)= 0, we have n equations for those m+ 1 variables. That should leave m+1- n independent variables so it looks to me like the kernel of T has dimension m-n+1 and the image has dimension m+1- (m-n+1)= n.
Of course, that's not a proof and may be completely wrong.
That seems correct :). But what if m+1<n? The kernel can't have a negative dimension, can it?
If that is the case, then we have more points than we have coefficients: but we will still have the trivial polynomial, p(x)= 0 for all x. The smallest the kernel can be is the 0 vector only and that has dimension 0. As long as [itex]m+1\le n[/itex], the kernel will have dimension 0 and the image will have dimension m+1.
