This problem has to do with mass and time
  • Thread starter Thread starter afcwestwarrior
    Mass Time
The problem involves a mathematical function representing the mass of water in a leaking container over time. The mass is expressed as a function of time, and the questions focus on determining the time at which the mass is greatest, the maximum mass, and the rate of change at specific time points.
  • Participants discuss the method for finding the maximum mass, with one suggesting the use of calculus for optimization. There is also a question about whether the first part of the problem involves finding when the mass function equals zero.
Some participants are exploring the optimization aspect of the problem, while others are questioning the interpretation of the first question. One participant has indicated they found a solution for part (a), which has led to further progress on the remaining questions.
The original poster expresses uncertainty about how to approach the problem, indicating a need for clarification on applicable equations and methods. There may be constraints related to the interpretation of the mass function and its behavior over time.
afcwestwarrior
Water is poured into a container that has a leak. The mass m of the water is given as a function of time t by m=5.00(t)^.8- 3.00t+ 20.00. with t being greater or equal to zero, m in grams, and t in seconds. (a) at what time is the water mass greatest (b) what is the greatest mass? in kilograms per minute, what is the rate of change at (c) t=2.00 s and (d) t=5.00s
how do i do this probelm
what equations can i use
if i knew what to do or sort of do i could attempt it
is question a asking me to plug in a time that will allow the equation to equal to zero
This is a problem in optimisation using calculus. Think of how to find the max and min of a function. That's all you need to do this problem, no physics involved.
I figured it out. It was 4 seconds for question (a) and that opened up the rest of the problems.
