| Thread Closed |
Optical fiber |
Share Thread |
| Aug25-08, 12:04 PM | #1 |
Optical fiber
Hi, i have a question about optical fiber and co2 laser
Can a co2 laser be cabled with optical fiber? Wavelength of 10 micron |
| Aug25-08, 12:38 PM | #2 |
Recognitions:
yes, that's how most industria lCO2 lasers work. The laser itself is somewhere safe, mecahnically stable and with lots of cooling. A fibre carries the laser power to the cutting head. Often they even have a separate small visible laser fibre wrapped around the main bundle - if there is any fault in the power bundle and the beam leaks out it quickly burns through the optical fibre which is detected and the laser shuts down.
Fibres are also used to bring the power from several lasers heads to one point, although this is more common with diode lasers. |
| Aug25-08, 06:28 PM | #3 |
| Aug26-08, 10:29 AM | #4 |
Recognitions:
Optical fiber
Probably not with fibres. They wouldn;t handle the power level sfor interially confined fusion and effects like dispersion would be a problem for the crititcal timing needed.
In a fusion experiment you have lots of space to build miles of lasers and beam lines on fixed optical tables so there is no need to use fibres. |
| Aug26-08, 01:58 PM | #5 |
Hmm, i think they use lenses and mirrors, and not optical fibers, or maybe a different kind of fiber...
| Aug26-08, 02:08 PM | #6 |
| Thread Closed |
Similar discussions for: Optical fiber
| Multipath dispersion of a pulse of light in an optical fiber. | Advanced Physics Homework | 3 | ||
| Material dispersion calculation (optical fiber) | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Optical Fiber attenuation coefficient | Electrical Engineering | 12 | ||
| optical fiber transmitter and receiver (photodarlington) | Electrical Engineering | 1 | ||
| biomimetics - optical fiber sponge | Biology | 5 | ||
