Destructive Interference in Sound Waves
The problem involves two speakers emitting sound waves at a frequency of 140 Hz, positioned 4.45 m apart, and a man walking towards one of the speakers. The questions focus on determining how many times he will experience a minimum in sound intensity and the distances from the pole at those moments, considering the speed of sound to be 330 m/s.
  • Participants discuss the wavelength calculation and the conditions for destructive interference, specifically the overlap of peaks and valleys of sound waves. There are inquiries about the appropriate equations to use and the reasoning behind the number of minima experienced.
Some participants have identified the wavelength and the conditions for sound cancellation. There is ongoing exploration of the calculations and the implications of the phase relationship between the sound waves from the two speakers. Multiple interpretations of the problem setup are being considered.
Participants are working under the assumption that sound reflections from the ground can be ignored, and they are focused on the direct sound waves from the speakers.
cmerickson21
Two speakers are driven by the same oscillator whose frequency is 140 Hz. They are located on a vertical pole a distance of 4.45 m apart from each other. A man walks straight toward the lower speaker in a direction perpendicular to the pole.
(a) How many times will he hear a minimum in sound intensity?
(b) How far is he from the pole at these moments? Take the speed of sound to be 330 m/s and ignore any sound reflections coming off the ground. (Give the first distances at which this happens.)
Welcome to PF. You might want to read this first:
https://www.physicsforums.com/showpost.php?p=785408&postcount=1
What formulas do you think apply?
I figured out that he hears a minimum twice. I have tried finding the wavelength and then using the Peak to Valley overlap equation which should apply to destructive interference where PVO=(m+.5)lamda m=0,1,2,3,... but that isn't working. What am I doing wrong should I not be using that equation? Do you have any ideas what I should be doing?
First of all what do you calculate for the wave length of the 140 hz sound wave?
Second of all at what point will the sound from two sources cancel each other out? They must be out of phase by how much? Which is what part of a wavelength?
I found the wavelength to be 2.36 by taking the velocity=330/the frequency=140. The sound will cancel out when the peak of one wave overlaps a valley of the other. Which will be when they are out of phase by half a wavelength.
That's what I get. OK. So if you move away from speaker A say, chosen for convenience as the problem is symmetrical, at what point is it that the sound from speaker A is exactly 1/2 wavelength out of phase with the two speakers?
  • · Replies 19 ·
  • · Replies 27 ·
