Uncovering the Mystery of UV Degradation in Polymers
  • Thread starter Thread starter Beasticly
    Polymers Uv
The discussion centers around the effects of ultraviolet (UV) radiation on polymer chains, exploring why UV rays are particularly harmful compared to other parts of the electromagnetic spectrum, such as visible light and x-rays. Participants delve into the mechanisms of polymer degradation, the energy of photons across different wavelengths, and the implications for polymer manufacturing and resistance to UV damage.
  • One participant questions why UV rays affect polymer chains significantly, suggesting a misunderstanding about the energy levels of UV versus visible light.
  • Another participant clarifies that shorter wavelengths correspond to higher energy photons, indicating that UV photons are indeed more energetic than visible light.
  • A participant expresses confusion about the classification of x-rays and gamma rays in relation to UV light, questioning if they are considered part of the UV spectrum due to their higher energy.
  • It is noted that while x-rays and gamma rays have higher energy, the sun emits significantly more UV radiation than these higher-energy rays, leading to greater collective damage to polymers.
  • Participants discuss the proportion of UV radiation in the solar spectrum compared to visible and infrared light, with one providing a graph to illustrate this point.
  • There is interest in understanding how additives can enhance UV resistance in polymers and whether the energy of bonds can be theoretically calculated or measured practically.
Participants express differing views on the classification of radiation types and the relative energy levels of UV versus visible light. While some points are clarified, the discussion remains unresolved regarding the implications of x-rays and gamma rays in the context of UV degradation.
There are limitations in the discussion regarding assumptions about the energy levels of different types of radiation and the specific mechanisms by which UV light causes polymer degradation. The relationship between photon energy and polymer bond energy is also not fully explored.
Beasticly
Hey guys, just trying to get my head around this one..
Why do UV rays effect polymer chains so much? I understand that they weaken the bonds within the chains to create free radicals which then go on to react with other things which eventually makes the whole chain degrade as a whole, but why are UV rays in particular so harmful?
Don't they have less energy/photon than visible light, which would make polymers mores susceptible to degration from visible light? Or is it something like there's more UV light rays than visible light rays?
I'm confused!
Thanks!
Also, I wasn't sure to put this in the physics section or here so feel free to move it if I've made a boo boo. :)
Chemistry news on Phys.org
Find a reference which breaks down the electromagnetic spectrum into the categories by wavelength/frequency. Use the E = hv (or its wavelength equivalent) relation to determine the energy of a photon in the infrared part of the spectrum, the visible part, the ultraviolet part, and the x-ray part. Which is the most energetic? What region of the EM spectrum is used to probe molecular vibrations? What region of the EM spectrum is used to probe electronic transitions? Do this first, and I think most of your confusion will be cleared up.
Good luck!
Nope, shorter wavelength = more energy per photon. So u.v. photons are more energetic than visible.
I'm confused!
Thanks!
In accordance with all of the explanations so far, the energy of the UV that creates hydrogen radicals from hydrogen gas for example, is the energy of the bond.
That makes a lot more sense now, but looking at a light spectrum I notice there's also xrays and gamma rays that have a higher energy again? Is it just that they are classed as UV too because they're higher than violet light?
Thanks!
Is it possible to find the energy of a bond? I'd like to look at how additives added to polymer to make the polymer UV resistant affect the energy between bonds, so if there's some sort of theoretical calculation I can do that'll be cool, or is it something you can only do practically?
No, they are considered separate from uv. Just as radio waves are not considered infrared.
So does the sun not emit xrays and gamma rays or something? If not, why are plastic manufactuers so worried about UV degration if there's xrays and gamma rays that will do more damage?
The sun emits a lot more uv radiation than it does x-rays and gamma rays. So while individual x and gamma photons are more energetic than uv, there are a lot more uv photons and collectively they do more damage.
But doesn't the sun emit white light that is made up of light of every wavelength? Is it just that UV occupies a greater proportion of wavelengths than any other sort of light?
Here is a graph showing the relative amounts of uv, visible, and ir radiation:
http://www.uvi.edu/SandM/Physics/SCI100/Downloads/SCI100MeteorologyLectures/SolarSpectrum.gif
As you can see, there is more visible and ir than uv. I was only saying the uv is more than x-rays and gamma rays, which are such a small amount that they would not even show up on this graph.
"White light" means there is light of every wavelength over some extended range, often just covering the visible region.
More info is at:
http://www.globalwarmingart.com/wiki/Image:Solar_Spectrum_png
http://en.wikipedia.org/wiki/Solar_radiation
http://www.google.com/search?source=ig&hl=en&rlz=&=&q=solar+spectrum&btnG=Google+Search
Nice find, Redbelly98.
  • · Replies 16 ·
  • · Replies 19 ·
11K
  • · Replies 20 ·
12K
11K
