Finding distance with known constant acceleration
The discussion revolves around calculating the distance traveled by a person coming to a complete stop under constant acceleration, specifically at an acceleration of 60g over a time period of 36 milliseconds.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to apply kinematic equations to find the distance, converting acceleration and time into usable values. Some participants question the interpretation of the acceleration value and the signs used in the equations.
Participants are actively engaging with the problem, with one offering a calculation attempt and others providing feedback on potential misunderstandings regarding variable definitions and signs. There is no explicit consensus yet, but guidance has been offered regarding the correct identification of initial and final velocities.
There is a noted confusion regarding the acceleration value expressed in terms of g's, as well as the proper application of kinematic equations in the context of the problem.
tater08
1. How far (in meters) does a person travel in coming to a complete stop in 36 ms at a constant acceleration of 60g?
2. X=Xo+ volt and V1=Vo +at
3. I converted 60g into 588.6 m/s^2 and then plugged it into the V1 equation to Find V1 which turns out to be 21.1896 m/s (after converting 36 ms into 0.036 seconds). I then entered the 21 m/s into the X1 equation and X=0+21.1896 * 0.036. I keep getting x = 0.76m. I am not confident that I am doing this question right or what I should be doing but that is my logic.
60g? Six, zero, g's?
yup 60 g's.
You've got v1 and v0 mixed up.
You are given v1; it is 0. You need to solve for v0. (and then make sure you've got your signs correct for both v and a.)
15K
