Selecting a Vacuum Pump: 5 CFM, Argon/Air, High Heat, Small Particles
  • Thread starter Thread starter M.Pesh
    Pump Vacuum
The discussion revolves around selecting an appropriate vacuum pump for specific applications, including handling small metal particles, achieving low vacuum levels, and managing high heat. Participants explore various pump types and specifications, including CFM ratings and vacuum pressure requirements, while addressing the needs of different users in manufacturing and degassing processes.
  • Homework-related
  • One participant suggests a venturi design by FESTO but expresses concern about wasting compressed air.
  • Another participant clarifies the vacuum pressure specification, questioning whether it should be 0-10 inHg and emphasizing the importance of the vacuum level needed.
  • A recommendation is made to consult a supplier for proper pump sizing, especially for those unfamiliar with vacuum pump specifications.
  • Clarification is provided that the intended vacuum is gauge pressure, which places it in the low vacuum range.
  • One participant advises using a roughing pump to back up a turbomolecular pump for achieving low vacuum in small chambers.
  • Concerns are raised that a turbo pump may be excessive for the stated requirements, suggesting that an air-driven ejector could be more suitable.
  • Another participant notes that 5 CFM is relatively small for a mechanical pump and reiterates the potential of using an air-driven ejector or a mini liquid ring vacuum pump.
  • A new participant seeks advice on a vacuum pump for degassing resin, mentioning a specific product and asking for feedback on its suitability.
Participants express differing opinions on the appropriate type of vacuum pump and the specifications needed for various applications. There is no consensus on a single best solution, as multiple viewpoints and suggestions are presented.
Some participants highlight the importance of understanding vacuum levels and the implications of different pump types, but specific assumptions and dependencies on definitions remain unresolved.
Individuals involved in manufacturing processes, particularly those dealing with vacuum applications for degassing or small particle handling, may find this discussion relevant.
M.Pesh
Hello,
I need some help selecting a vacuum pump.
Required specs
- 5 CFM
- vacuum (0-10 in/mg)
- possibility of sucking up small metal particles (size:50-200 microns)
- working fluid is argon/air
- needs to handle high heat
My original feeling was to go with a venturi design made my FESTO. But I don't like the idea of wasting compressed air.
Do you mean 0-10 inHg? (http://en.wikipedia.org/wiki/Inch_of_mercury" ). When you talk about vacuum pumps it is the zero part in the 0-10 that makes all the difference. How close to 0 does your vacuum need to be.
There are different gradations in vacuum:
Atmospheric pressure 760 Torr 101.3 kPa
Low vacuum 760 to 25 Torr 100 to 3 kPa
Medium vacuum 25 to 1×10-3 Torr 3 kPa to 100 mPa
High vacuum 1×10-3 to 1×10-9 Torr 100 mPa to 100 nPa
Ultra high vacuum 1×10-9 to 1×10-12 Torr 100 nPa to 100 pPa
Extremely high vacuum <1×10-12 Torr <100 pPa
For medium vacuum you can use a roughing (positive displacement, rotary vane) pump. http://www.varianinc.com/cgi-bin/nav?products/vacuum/pumps/index&cid=KKKLPLPJFO".
I would highly recommend that if you are not used to spec'ing out a pump yourself that you go through a supplier that can size one for you. Especially with vacuum pumps. Look for your local reps under something like ThomasNet.
Thanks for the help,
I should have clarified myself better, What I was looking for was 0-10inHg gauge pressure This leaves me well into the low vacuum region.
If you want to get to low vacuum and your chamber has a relatively small volume you should use a roughing pump to back up the turb-mech pump. Also try the company Lybold (I think it is spelled correclty) located in Delmont, PA.
A turbo pump is overkill. He only needs 10 inHg gauge pressure, which is around 20 inHg or 500 Torr absolute pressure.
10 inHg Vac = 254 mmHg Vac = 506 Torr = 674 mbar = 67.4 Kpa
this is a depression, but not really to be considered as a vacuum.
Also 5 cfm (8.5 m³/h) is very small for a mechanical pump: you original idea of an air driven ejector is probably the best solution. If compressed air is not available you may look for a mini liquid ring vacuum pump.
Manufacturers for ejectors and vacuum pumps are listed in www.vacuum-guide.com
i need some help also in choosing a vacuum pump. i am currently in the process of manufacturing small plastic parts. a serious problem i need to fix is the air bubbles trapped within the resin compounds, thus resulting in a flawed final project. i am new to the degassing/vacuum chamber world so forgive my lack of knowledge in this field. i do not need a massive pump for i am only degassing no more than 5 fl oz of resin with a viscoscity around 500 cps with the possibly of up to 2000 cps. i was looking at a vacuum pump made by Robinair product id rob15800 with a 8cfm rating. i was thinking of linking it up to a vacuum chamber to perform the degassing. i wanted to see if a that company was any good and if that pump would do the job, and b if anyone has a better suggestion...any help would be much appreicated. thank you for your time
  • · Replies 18 ·
12K
  • · Replies 19 ·
11K
  • Poll Poll
