Simplifying Equations with Exponential Terms
The discussion revolves around simplifying an equation involving exponential terms, specifically the expression -e^((-1/2)*x^2)*(x^2-1)+2*e^((-1/2)*x^2)*x. Participants are exploring methods to combine and factor the exponential components with polynomial expressions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the possibility of combining exponential terms and simplifying the polynomial components. There are attempts to factor out common terms and questions about the correctness of these steps. One participant mentions using software to simplify the expression, leading to confusion about the resulting terms.
The discussion includes various attempts to simplify the equation, with some participants providing insights into factoring and combining terms. There is acknowledgment of differing interpretations of the simplification process, and while one participant claims to have solved it, the details remain unclear.
Participants are working under the constraints of homework guidelines, which may limit the use of external resources or software for simplification. There is also a mention of confusion regarding specific terms in the final simplified expression.
riordo
Can you help me simplify the following equation: -e^((-1/2)*x^2)*(x^2-1)+2*e^((-1/2)*x^2)*x.
I've been guessing that you can combine the e^((-1/2)*x^2) components and thus end up with (x^2-1)x+e^((-1/2)*x^2)*x. Please let me know. Thanks.
The most I can simplify it is just an exp term and a polynomial...
[tex]e^{-\frac{x^2}{2}}(-x^2+2x+1)[/tex]
Yes, you can factor out the e(-1/2)x^2x2 but you don't appear to have done it correctly! removing e(-1/2)x^2x2 from the first term leaves -(x2-1) and from the second leaves x. Removing it from both gives e(-1/2)x^2x2(-(x2-1+x)= -e-(1/2)x^2x2(x2- x+ 1).
Thank you. It appears that either you can combine the negative and positive e^((-1/2)*X^2) terms or eliminate the term by adding a negative value on both sides of the = sign. However that seems to me to make it more complicated. When I plug this into Mathematica software it simplifies to -e^((-1/2)*x^2)*x(x^2-3). I don't understand how it comes to this solution especially the (x^2-3). Let me know if you have any insight to what I am missing.
Thank you very much.
Solved. Thanks for the help.
  • · Replies 18 ·
