Find the curvature of the curve
  • Thread starter Thread starter whynothis
    Curvature Curve
The discussion revolves around finding the curvature of a parametric curve defined by \(\alpha(t) = (x(t), y(t))\). The original poster presents an equation for curvature and attempts to derive it using the chain rule, expressing concerns about their approach and results.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use the chain rule to relate derivatives with respect to arc length and parameter \(t\). Some participants suggest starting with the parametric representation and differentiating to find the unit tangent vector, leading to the curvature expression.
Participants are exploring different methods to derive the curvature formula. Some guidance has been offered regarding the differentiation process and the representation of the curve, but there is no explicit consensus on a single approach. The original poster expresses curiosity about potentially more elegant methods.
The discussion includes the challenge of working with a non-arc length parameterized curve and the implications this has on the derivation of curvature. There is an acknowledgment of the complexity involved in the calculations and the need for careful manipulation of terms.
whynothis
Given a parametric curve, [tex]\alpha(t) = (x(t),y(t) )[/tex], not necessarily arc length parameterized show that the curvature is given by:
[tex]k = \frac{x'y'' - y'x''}{|\alpha'|^{3}}[/tex]
As I understand this the curvature is defined from the point of view of a arc length parameterization as
[tex]k = |\frac{d^{2}\alpha(s)}{ds^{2}}|[/tex]
So I tried using the chain rule...
[tex]\frac{d\alpha}{ds} = \frac{d\alpha}{dt}\frac{dt}{ds}[/tex]where dt/ds = 1/(ds/dt) = [tex]1/|\frac{d\alpha}{dt}(t)|[/tex]
Then I differentiated again to get...
[tex]\frac{d}{ds} \frac{d\alpha}{dt}\frac{1}{|\frac{d\alpha}{dt}(t)|} = \frac{d}{dt}\frac{dt}{ds} \frac{d\alpha}{dt}\frac{1}{|\frac{d\alpha}{dt}(t)|}=\frac{d^{2}\alpha}{dt^{2}}\frac{1}{|\frac{d\alpha}{dt}(t)|^{2}}}-\frac{d\alpha}{dt}\frac{\alpha'\cdot\alpha''}{|\frac{d\alpha}{dt}(t)|^{4}}[/tex]
This isn't what I should get. It seems that I am clearly missing something since all the problems I try and do along these lines I am stuck on. Does anyone have any insight on this?
Thanks in advanced
Don't you think you ought to start by representing the curve in parametric form (x(t),y(t))? Now start differentiating that. The unit tangent is (x',y')/sqrt(x'^2+y'^2). The curvature is the norm of the derivative of that.
Thanks for the advice. The expression turned out to be right I just needed to do a little foot work to get it in the same form : )
I am curious to know, however, if you had a more elegant way in mind?
Nah. Just differentiate, cancel some terms and collect stuff.
