Is Wave-Particle Duality of Light a Misleading Concept?
The discussion revolves around the concept of wave-particle duality of light, exploring whether this duality is a misleading concept. Participants examine the nature of light at the quantum level, the implications of classical versus quantum descriptions, and the physical characteristics of light.
  • Some participants propose that light exists in both wave and particle forms, suggesting that this duality is difficult to reconcile with classical concepts.
  • Others argue that at the quantum level, light is fundamentally a quantum-mechanical phenomenon described by quantum electrodynamics (QED), which encompasses both wave-like and particle-like behavior without relying on classical interpretations.
  • A participant presents a theory that light consists of particles (photons) moving in a wavelike pattern, suggesting this could unify the wave-particle duality into a single form.
  • Another participant emphasizes that classical concepts of shape and form do not apply to light, which is better described mathematically in quantum terms.
  • There is a discussion about the physical shape or form of light, with some participants questioning whether light can be said to have a shape at all.
  • One participant draws a parallel between light and electrons, noting that while electrons are described as point particles with no size, they still possess mass, indicating that classical attributes may not apply to quantum entities.
Participants express differing views on the nature of light, with no consensus reached regarding the validity of wave-particle duality or the applicability of classical concepts to quantum phenomena.
Participants highlight limitations in using classical concepts to describe quantum phenomena, indicating that traditional notions of shape and form may not be applicable to light or other quantum entities.
ronjanec
Sometimes light exists in the form of a wave and sometimes light exists in the form of a particle or wave/particle duality. Light existing in two completely different forms does not make sense to me but the experiments have proved this right? I have a theory that light is actually a stream of particles/photons moving in a wavelike up and down pattern that would prove wave/particle duality true in one existing form that I could believe in.
The particles are moving so fast they appear to us as a wave and the experiments that prove light is a particle are misleading in that they destroy the wave. Any comments?
At the quantum level, light exists in a single form: as photons, which are quantum-mechanical objects described by the theory of quantum electrodynamics (QED). Some aspects of their behavior are particle-like and others are wave-like, but it all comes from the same mathematical description.
jtbell: What do you personally think of my theory? Do you think I could be right about this? I am kind of saying what you are saying or believe that light is a stream of photon particles at the quantum level making up a wave?
You are missing the point: "waves" and "particles" are classical concepts and light is purely a quantum mechanical phenomena (albeit one that can often be well described by classical equation like Maxwell's equation); there is no such thing as "classical light". If you want an accurate description of light you need to use quantum electrodynamics(QED)
Hence, it is not possible to explain what light is using concepts that "make sense" to us; light is -just as most quantum phenomena- simply very weird.
Fortunately this does not stop us from formulating very successful theories that can describe light (i.e. predict the outcome of experiments) using math.
Quantum electrodynamics is a very good theory and is -as far as we know- the "whole truth" about light (as long as gravity is not involved).
Nowadays we can do all sort of funny things with photons in the lab, see e.g.
http://focus.aps.org/story/v22/st8
Ok but what shape or form does the light in my office exist in? It has to have some physical shape or form if light exists and moves around?
What shape or form is the water that you drink?
Zz.
I remember seeing a theoretical illustration of Einstein running alongside a beam of light and the light in this example was in the form of a wave? Are you both trying to tell me that light does not have any shape or form whatsoever?
Shape and form are to a large extent classical concepts.
Let me give you another example: The electron is -as far as we know- a point particle; i.e. it does not have a size (zero volume) but it still has mass.
Hence, it would obviously be wrong to attribute a "shape" to an electron.
But -and this is the important part- even though no one can really "visualize" an electron this does not stop us from describing it mathematically, the same is true for light.
  • · Replies 36 ·
10K
  • · Replies 58 ·
  • · Replies 17 ·
