Is Firefox's High Memory Usage a Known Issue and How Can It Be Fixed?
  • Thread starter Thread starter Chen
    Firefox Memory
The discussion revolves around the high memory usage of Firefox, with participants sharing their experiences and seeking potential solutions. The scope includes user experiences, technical explanations, and suggestions for alternatives or adjustments to settings.
  • One participant reports that Firefox's memory usage increased to 90MB shortly after installation on a new computer, questioning whether this is a known issue and seeking a fix.
  • Another participant explains that the high memory usage is due to memory caching, which allows for faster page loading but consumes more RAM.
  • A different participant suggests that Firebird should only use around 20MB of RAM, depending on the number of tabs open, and questions how the 90MB figure was determined.
  • Concerns are raised about Firefox consuming more than 30MB of memory, with one participant noting that their graphics programs use significantly less memory.
  • Some participants speculate about the possibility of a memory leak if Firefox continues to consume more RAM over time.
  • One user mentions experiencing cursor issues while typing, leading them to suspect a virus due to the high memory usage and erratic behavior.
  • A suggestion is made to modify Firefox's configuration settings to potentially reduce memory usage.
  • Several participants express frustration with Firefox's performance compared to other browsers, suggesting alternatives like Opera.
Participants express a range of views on Firefox's memory usage, with no consensus on whether it is a bug or an expected behavior due to caching. Some participants agree that the memory usage is excessive, while others propose that it may be normal under certain conditions.
Participants reference various methods for assessing memory usage, such as the Windows Task Manager, and discuss potential configuration changes without reaching a definitive solution. The discussion includes unresolved technical details regarding memory management and user experiences.
Chen
This is getting ridiculous. With my last installation of Firefox, which was an upgrade from Firebird, it used to take up a lot of memory and frequently halt. At the time I attributed this to the fact that it was not a new installation, but an upgrade from a previous version.
However, now I've installed Firefox on my brand new computer and a day later it is already using 90MB of memory and counting. Even Internet Explorer uses less than this. I doubt all programs on my computer combined would use up so much memory.
Is this a known problem? Is there a fix? I've posted this also on the MozillaZine forums, but they get (literally) thousands of help requests every day and most go unnoticed. If I can't solve this problem I will have no choice but to go back to IE, as much as I don't want to.
Computer science news on Phys.org
It's not a bug, it's called memory cache. Instead of just caching pages on the hard drive (which it does), pages are also put into ram so clicking the back button makes the page load instantly.
I don't know how to turn down the amount of memory cache in Firefox, just try poking around in the options.
If you turn memory cache off, clicking the back button will not load instantly, and you will not be able to recover text in input boxes. What that means is if the forum gives you an error and doesn't post, clicking the back button will not recover what you attempted to post; that's why I always leave memory cache on.
Try Opera. It's as safe as Mozilla but has more options than Firefox. It's easy to disable memory cache in Opera :wink:.
Firebird should only take up around 20MB of RAM, but it also depends on how many tabs you have open as well. I'm pretty sure caching is done to the hard drive, not the RAM. How exactly are you coming up with the 90MB+ figure. Are you looking at the Windows Task Manager?
may i ask how come you know how much memory is consumed when using firefox and when opening tabs ?
Thanks
Cache or not, Firefox is not supposed to take up more than 30MB of memory. I run several graphics programs and none of them even comes close to 90MB, that's insane. I get that figure from the task manager, yes. Vance, press Ctrl+Alt+Delete once and go to the Processes tab. I've been told to try a nightly build which might fix this problem, so I guess I have no other choice but to do so.
Thanks Chen,
I don't think it's caused by having too many tabs open, by the way. Just for Firefox to completely load after starting it, it uses a bit more than 30MB. And then every page is a couple more hundred kilobytes... if Shawn is correct about caching the data in RAM, they could at least delete it once I leave the site or close the tab! No wonder that if I leave it running for a few hours it uses so much memory...
Chen, if your leaving Firefox open and it is consuming a lot more RAM a few hours later there may be a memory leak. You should download the source for firebird and try to debug the problem yourself. :wink:
...or I could just switch to a software that isn't filled with bugs. :smile:
right now my firefox is using 124 868k of memory. i never notice anything because i have 512MB to i have plenty 2 spare but it shouldn't be doing this! to make it worce, its been doing this weird thing lately. at random times it will just move the curser left while I am typing. as if sum1 pressed the left. done it about 20 times in this post alone. u can imagine how annoying it is!
im starting to think its a virus or sumthin! huge memory usage and annoying/weird things happening.
if you type
about:config
in the Firefox' adres bar you get a list of many settings that you can change, I guess that if you turn browser.cach.memory.enable to false the memory usage will drop substantially
Hmm, my Mozilla Browser component of the http://www.mozilla.org/products/mozilla1.x/ is using less than 10MB of RAM at the moment. :smile:
  • · Replies 46 ·
  • · Replies 34 ·
15K
  • · Replies 30 ·
  • · Replies 21 ·
