Astrophysics- Calculate the altitude of a geosynchronous orbit
The discussion focuses on calculating the altitude of a geosynchronous orbit, comparing it to the altitude of the International Space Station, and determining the orbital period of the ISS. The scope includes mathematical reasoning and application of gravitational equations.
  • Mathematical reasoning, Homework-related, Technical explanation
  • One participant presents calculations for the altitude of a geosynchronous orbit and expresses uncertainty about the correctness of their approach and the value of the gravitational parameter (mu).
  • Another participant identifies the equation used as Kepler's third law and suggests that it can be applied to both parts of the problem, emphasizing the importance of unit consistency.
  • A question is raised about whether the same equation can be used for both calculating the altitude of the geosynchronous orbit and the orbital period of the ISS.
  • A later reply clarifies that the same law applies, but the approach differs depending on whether the radius or the period is being calculated.
Participants do not reach a consensus on the correctness of the initial calculations or the specific values to use, indicating that multiple views and uncertainties remain in the discussion.
Participants express uncertainty about the gravitational parameter (mu) and the application of equations, highlighting potential limitations in their understanding of the material covered in class.
Students studying orbital mechanics, astrophysics, or related fields may find this discussion relevant for understanding geosynchronous orbits and the application of Kepler's laws.
sleepyhead212
a)Calculate the altitude of a geosynchronous orbit (an orbit that has an orbital period of one sidereal day)(altitude is measured from the surface of the earth/ The "r" in gravitational equations is always measured from the center of mass of an object. one may assume a circular orbit.)
b) how does the altitude of this geosynchronous satellite compare to the average 354 km altitude of the International Space Station?
c) Calculate the orbital period of the international Space Station (assume circular Orbit)
this was my attempt
a= (mu*(1/(2pi))^2)^(1/3)
a= (398600(1/(2pi))^2)^(1/3)
a=21.6
but for b) I am not sure if my prof. wants a word explanation or to solve the actual difference so i provided a word explanation
then for c)
T = ((2\pi)/(mu)a^(3/2))^(1/3)
but am unsure what mu would be.
i'm not sure if what I'm doing is correct because we never went over this in class so i tried do this based off internet research. any help would be appreciated
The equation you have is Keplers third law (ignoring the mass of the satelite)
( period / 2pi )^2 = radius^3 / GM
If you plugin G and M=mass of the Earth you should get the right answer, be careful of the units.
can this equation be used for both part a and c?
The law describing their behaviour is the same, you simple have to find radius in one case given the period and the period in the other case given the radius.
  • · Replies 53 ·
  • · Replies 18 ·
  • · Replies 20 ·
10K
