Finding Efficiency from a P-V Graph
The efficiency of a reversible heat engine can be determined from a P-V graph by analyzing the area enclosed by the process curves. In the discussed scenario, the P-V diagram features argon as the working substance, with specific points indicating isothermal processes at 423 K. The efficiency can be calculated using the formula for thermal efficiency, which is the ratio of work output to heat input, derived from the areas under the curves representing processes ab and ac.
  • Understanding of P-V diagrams and their significance in thermodynamics
  • Knowledge of the ideal gas law and properties of monatomic gases
  • Familiarity with the concept of thermal efficiency in heat engines
  • Basic principles of reversible processes in thermodynamics
  • Study the derivation of the thermal efficiency formula for heat engines
  • Learn how to interpret P-V diagrams for different thermodynamic processes
  • Explore the properties and behavior of argon as a monatomic ideal gas
  • Investigate real-world applications of reversible heat engines and their efficiencies
Students and professionals in thermodynamics, mechanical engineers, and anyone interested in the efficiency of heat engines and the analysis of P-V diagrams.
yossup
uh...just wondering but how do you find out the efficiency from a P-V graph?
depends on the engine's process
The figure is a PV diagram for a reversible heat engine in which 1.0 mol of argon, a nearly ideal monatomic gas, is initially at STP (point a). Points b and c are on an isotherm at T = 423 K. Process ab is at constant volume, process ac at constant pressure.
How would I go about finding the efficiency from such a graph?
  • · Replies 20 ·
