How to Find the Length of a Graph Using Calculus?
  • Thread starter Thread starter cse63146
    Graph Length
The discussion revolves around determining the length of a graph defined by the function f(x) = (x^5)/10 + (1/(6x^3)) using calculus, specifically through the application of the arc length formula.
  • Participants discuss the calculation of the derivative f'(x) and its square, questioning the correctness of the initial computations. There is mention of a potential trick to simplify the expression under the radical in the arc length formula.
Some participants are exploring the correctness of the derivative and its implications for the arc length calculation. Suggestions have been made to express the term under the radical as a perfect square, indicating a potential direction for further exploration.
There is an indication of confusion regarding the manipulation of the function and its derivative, as well as the need for clarification on the steps involved in the arc length calculation.
cse63146
Determine the length of the following graph:
[tex]f(x) \ = \ \frac{x^5}{10} + \frac{1}{6x^3}[/tex]
length of a graph: [tex]\int \sqrt{1 + f'(x)^2}dx[/tex]
so [tex]f'(x) = \frac{x^4}{2} -\frac{1}{18x^4}[/tex]
[tex]f'(x)^2 = \frac{x^8}{4} + \frac{1}{18} + \frac{1}{324x^8}[/tex]
Is f'(x)^2 correct?
Did I even need to expand, or is there some trick to this?
There is almost always a trick to length of arc problems and the trick is almost always make the expression under the radical into a perfect square. Add 1 to f'^2 and you will see that you can. Except fix f'(x) first. I get x^4/2-1/(2*x^4). Why don't you?
I see what I did wrong. I "brought up" the 6 as well, so I wrote it as 6x^-3
Ok, so can you square it and then express the expression under the radical as a perfect square? I'm betting you can.
  • · Replies 105 ·
13K
  • · Replies 21 ·
