| Thread Closed |
characteristic equation |
Share Thread |
| Sep23-08, 01:22 AM | #1 |
im trying to find the characteristic equation of a circuit with a current source and 3 elements all in parallel: a resistor and 2 inductors L1 and L2. 2. Relevant equations i believe the current can be calculated as: i(t) = v(t)/R + iL1(t) + iL2(t) 3. The attempt at a solution is this anywhere close? (1/R)dv/dt + 1/L1(v) + 1/L2(v) = 0 i guess i don't understand what is equated in a characteristic equation. |
| Sep23-08, 08:27 PM | #2 |
combine L1 and L2 in parallel into L_total (assuming you don't care mutal inductance), now you have one less component.
| Sep24-08, 11:38 AM | #3 |
Recognitions:
Is the current source a constant source or one of a function of time? And how could you write iL1 and iL2 as though the two i's for both are the same? Is it given that the inductance of both are the same?
| Sep27-08, 08:50 AM | #4 |
characteristic equationThe characteristic equation is the algebraic equation you obtain when you apply the Laplace transformation to your differential equation. |
| Thread Closed |
Similar discussions for: characteristic equation
| characteristic of R | Calculus & Beyond Homework | 0 | ||
| VI Characteristic | Engineering, Comp Sci, & Technology Homework | 9 | ||
| VI Characteristic | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Characteristic? | Calculus & Beyond Homework | 3 | ||
| characteristic equation | Differential Equations | 13 | ||
