Question: Plasma, fluids, and stuff
  • Context: Undergrad
  • Thread starter Thread starter Adam
    Fluids Plasma
The discussion centers on the classification of plasma in relation to gases and liquids, exploring definitions and the role of energy in determining states of matter. Participants examine whether plasma should be considered an ionized gas or an ionized fluid, and the implications of energy levels on these classifications.
  • One participant questions whether plasma is an ionized gas or an ionized fluid, suggesting that energy levels might determine the state of matter.
  • Another participant proposes that plasma is correctly termed an ionized gas, indicating that it transitions through phases based on energy input.
  • A different viewpoint emphasizes that the distinction between gas and liquid is primarily due to intermolecular forces and particle masses, rather than just energy levels.
Participants express differing views on the classification of plasma, with no consensus reached on whether it should be defined as an ionized gas or fluid. The role of energy versus intermolecular forces in determining states of matter is also contested.
Participants highlight various assumptions regarding definitions of states of matter and the factors influencing phase transitions, but these remain unresolved within the discussion.
Adam
Keep in mind I have not studied fluid dynamics or plasma stuff at all...
Now, both gases and liquids are fluids. Is a plasma an ionised gas, or an ionised fluid? The reason I ask is because the big difference between the gas and liquid forms of various things is the amount of energy. Is the amount of energy involved the deciding factor of whether something is a plasma or not? If you apply a charge to the neon in a light, it is a plasma. But what if that neon is cooled to liquid, then a charge is applied?
Basically I'm looking for a definition of plasma that covers the difference between liquid and gas.
Thanks.
either way to get it to a plasma state it will climb the phases to its superenergized form, but the correct termonology is ionized gas.
[/B]
i suppose it would energize to the next highest state before plasma, a gas. (depending on how much it is energized)
No, actually it's not -- the big difference is in strength of the interatomic (intermolecular) forces and the masses of the particles. Any particle of any gas or liquid will have 3/2 kT average thermal energy. If the interatomic forces are small and the particles lightweight (therefore with large thermal velocities), the substance will be a gas. If the interatomic forces are large and the particles massive (therefore with small thermal velocities), the substance will be a liquid. This is the reason that different substances occupy different phases at any given temperature.
- Warren
edit: woops
Excellent, thanks.
