Why is the set of all lines through the origin homeomorphic to the circle S1?
  • Thread starter Thread starter jacobrhcp
The set of all lines through the origin, denoted as P1, is homeomorphic to the circle S1. The mapping f from S1 to S1/R, where R is defined by the relation (x,y) in R iff x=y or x=-y, is continuous and surjective. To establish that P1 and S1 are homeomorphic, it is essential to demonstrate that f is injective and possesses a continuous inverse. The confusion arises from the interpretation of the origin's position, which can be conceptualized as the north pole in a stereographic projection of the circle.
  • Understanding of homeomorphism in topology
  • Familiarity with the concept of stereographic projection
  • Knowledge of continuous functions and their properties
  • Basic understanding of the circle S1 in the real plane
  • Study the properties of homeomorphisms in topology
  • Learn about stereographic projection and its applications
  • Explore the concept of continuous functions and their inverses
  • Investigate the topology of the circle S1 and its representations
Mathematicians, students of topology, and anyone interested in understanding the relationships between geometric shapes and their topological properties.
jacobrhcp
Prove P1 is homeomorphic to S1
P1 is the set of all lines through the origin. I have shown for myself that this is homeomorphic to S1/R, where R is given by: (x,y) in R iff x=y or x=-y.
This also shows there is a continuous surjective map f from S1 to S1/R. To prove S1 and S1/R are homeomorphic I need to show that f is injective, and that it has continuous inverse.
However, I think there is something fundamentally wrong with my understanding of the problem, because I cannot imagine the map f being injective. To me it feels as though S1/R is the same as the 'northern hemisphere' of S1, because it sends -x and x to the same line through the origin (where x is an element of the real plane on the circle S1). So wouldn't that imply that f(x)=f(-x) while x is not equal to -x, so f is not injective, so P1 is not homeomorphic to S1?
Anyone who can tell me why I'm fundamentally off here, and give me a push in the right direction, thank you.
Jacob
Think of the origin as a point at the top (north pole?) of the circle. As the lines pass through the origin they project on to the circle like a stereographic projection.
Ah I was taking the centre as origin... it confused me deeply.
But then again, isn't S1={x in the real plane | ||x||=1}... so why do we get to say the origin is on the top of the circle instead of in the middle?
This new view will probably help me take a better shot at the problem later this evening.
