Accident Analysis: Find Speed of Sedan and SUV Before Collision
  • Thread starter Thread starter AnNe11
    Accident Analysis
The discussion revolves around a collision analysis involving a sedan and an SUV at an intersection. The problem requires determining the speeds of both vehicles just before the collision, given their masses, the coefficient of kinetic friction, and the distance they slid after the impact.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conservation of momentum and the effects of friction on the vehicles' motion post-collision. There is an exploration of calculating initial velocities based on the distance traveled and the coefficient of friction. Some participants question the assumptions about the masses and the setup of the problem.
Some guidance has been provided regarding the calculations of acceleration and initial velocity. Participants are actively engaging with the problem, sharing their attempts and seeking clarification on specific steps in their reasoning.
There are variations in the figures used by participants, indicating potential discrepancies in the problem setup. The original poster's interest appears to have waned, leading another participant to propose their own figures for analysis.
AnNe11
A 1400 sedan goes through a wide intersection traveling from north to south when it is hit by a 2500 SUV traveling from east to west. The two cars become enmeshed due to the impact and slide as one thereafter. On-the-scene measurements show that the coefficient of kinetic friction between the tires of these cars and the pavement is 0.750, and the cars slide to a halt at a point 5.39 west and 6.55 south of the impact point.
Part A -
How fast was sedan traveling just before the collision?
Part B
How fast was SUV traveling just before the collision?
Welcome to PF!
Part A -
Part B
Hi Anne! Welcome to PF! :smile:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
Hi, it look like it's been a while since this thread was posted in, but I happen to have the same question.
I will post my attempts at solving it below.
First, if you don't mind, I would like to supplement my own figures for the question instead of the original posters since it seems he (or she) has lost interest in the question.
A 1600 kg sedan goes through a wide intersection traveling from north to south when it is hit by a 2000 kg SUV traveling from east to west. The two cars become enmeshed due to the impact and slide as one thereafter. On-the-scene measurements show that the coefficient of kinetic friction between the tires of these cars and the pavement is 0.750, and the cars slide to a halt at a point 5.57 m west and 6.28 m south of the impact point.​
I believe the momentum before the collision will be the same after the collision.
To find the momentum after the collision, I need the mass of the enmeshed cars (3600 kg I believe) and its speed. Since I was given the coefficient of kinetic friction and the distance traveled until rest, I think I calculate the acceleration, then pair it with distance in the equation V2 = V02 + 2ad, where d is the length of the hypotenuse between 5.57 m and 6.28 m (8.3942 m). I
I'm not sure about the acceleration, but my attempt has put the net force equal to the coefficient of friction multiplied by the mass and the acceleration due to gravity
(ma = kmg). This would yield 7.35 for the acceleration, giving me 11.1083 as the initial velocity when plugged into the equation in the preceding paragraph.
However, I am not sure how go from there.
Any help would be much appreciated, thanks!
Welcome to PF!
Hi ifyjo! Welcome to PF! :smile:
Yes, the deceleration is µg, = .735, and the distance is 8.3942, so the "initial" velocity is 11.108 in the direction given.
Now, you know the direction of the two cars just before the collision, so call their speeds u and w, resolve 11.108 into west and south components and use conservation of momentum. :wink:
(incidentally, since you'll be resolving the "initial" velocity into west and south components anyway, you could have used the same deceleration on each component separately, without bothering about the hypotenuse!)
Thanks so much for your help tiny-tim. I got it all to work out fine.
9K
