| Thread Closed |
Square root of pi |
Share Thread | Thread Tools |
| May17-04, 04:48 PM | #1 |
Square root of pi
The square root of pi is 1.777245.... I know. But my math teacher says its impossible to determine a square root of an irrational number. Can anyone shed any light on this? is it or is it not possible to determine the square root (or any root) of an irrational number?
| May17-04, 04:55 PM | #2 |
Recognitions:
you would have to explain what you mean by 'determine'
| May17-04, 05:12 PM | #3 |
I mean, Is it possible to arrive at a root of an irrational number?
| May17-04, 05:29 PM | #4 |
Recognitions:
Square root of pi
that is still a vague question that needs elucidation. how on earth would you "arrive" at root two? as root two squares to 2, surely if one can 'arrive' at root two, one can 'arrive' at root of root two since that is then the fourth root of 2, and if one can 'arrive' at square roots why not fourth roots.
| May17-04, 05:49 PM | #5 |
Mentor
Of course we cannot specify ALL digits of any irrational number, we can determine the number to pretty much any specifed precision.
| May17-04, 08:59 PM | #6 |
The square root of Pi can't be constructed with straightedge & compass because Pi is transcendental. It's possible to construct (or "arrive at" ?) the square root of an irrational number that isn't transcendental though.
| May18-04, 12:22 AM | #7 |
So IOW, it is not possible to construct or "arrive at" a root for an irrational number?
not even, as Integral said, an approximate? |
| May18-04, 01:18 AM | #8 |
However, as fourier jr. said, the particular technique known as "geometric construction" cannot be used to approximate transcendental numbers. |
| May18-04, 04:06 AM | #9 |
Recognitions:
there is nothing to stop you constructing the fourth root of 2 using compass and straightedge ie the square root of an irrational number, you might also be able to construct irrational roots of transcendental numbers as well. however did you even mean constructibility using ruler and compass?
of course the question springs to mind: how did you 'arrive' at or 'determine' the orginial irrational number that you wanted to find the root of? i think you might mean "can we have an exact formula for the n'th position of the number in decimal notation" which of course makes the mistake of presuming that there is something special about decimal expansions, and that they are real numbers. if you use continued fractions you'll find an 'exact' formula for many different irrational numbers. |
| May18-04, 07:05 AM | #10 |
Recognitions:
You can obviously say that:
[tex]\sqrt{\pi} = 2 \int_0^{\infty} e^{-{x^2}} dx[/tex] It's all a matter of perspective, if you mean it can not be shown exactly in terms of decimal representation then neither can any other irrational number. |
| May18-04, 07:28 AM | #11 |
If, by "construct" you mean "construct, as in Euclidean geometry, with compasses and straightedge", then you CAN exactly construct any number that is "algebraic of order a power of two" and possible to construct such a number that is an approximation, to any degree of accuracy, of any number. |
| May18-04, 09:56 AM | #12 |
Well pi squared is irrational, so if we can' 'determine' the root of an irrational number we can't 'determine' pi.
Perhaps your teacher was talking about transcendental numbers which are irrational (though no all transcendental numbers are irrational); pi is a transcendental number. If a number is transcendental it is not a root to the equation: [tex]a_n x^n + a_{n-1}x^{n-1}+...+a_1 x + a_0 = 0[/itex] where [itex]a_i[/itex] are intergers. |
| May18-04, 11:17 AM | #13 |
Recognitions:
jcsd, about the bit in brackets: please show me a transcendantal (real) number that is rational then.
| May18-04, 12:44 PM | #14 |
| May19-04, 05:10 PM | #15 |
so you can't have something like [itex](x-\pi)^2=0[/itex]? |
| May19-04, 05:18 PM | #16 |
[tex]x^2 - 2\pi x + \pi^2 = 0[/tex] Therefore neither [itex]a_0[/itex] (i.e. [itex]\pi^2[/itex]) nor [itex]a_1[/itex] (i.e. [itex]2\pi[/itex]) are intergers. |
| May19-04, 11:08 PM | #17 |
yeah the polynomial has to have integer coefficients
| Thread Closed |
| Thread Tools | |
Similar Threads for: Square root of pi
| What is: Square root cut? | General Physics | 10 | ||
| what is the square root of i^2 | General Math | 8 | ||
| square root | Calculus & Beyond Homework | 4 | ||
| Square root | General Math | 13 | ||
| Square Root | Calculus | 4 | ||
