| Thread Closed |
Rotations in Complex Plane |
Share Thread | Thread Tools |
| Sep30-08, 08:49 PM | #1 |
I'm reading this book on modern geometry and I was wondering if I'm doing these problems right:
if I'm give a point 2+i and I'm suppose to rotate is 90 degrees first I move it to the origin T(z)=z-(2+i) second, I rotate it e^(pi/2*i)*z I'm not sure how to interpret that algebraically then i replace it T^-1(z)= z+(2+i) Am I actually doing this right, the book I'm reading is kind of old and doesn't have many worked examples. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep30-08, 09:43 PM | #2 |
A 90 degree rotation is accomplished by multiplication by i.
(2+i)i = 2i -1 |
| Sep30-08, 10:03 PM | #3 |
then how is a 45 degree rotation accomplished, in the one example (ill type the whole thing out)
rotate by 45 degrees at point i f(z)=z-i g(z)=e^(i*pi/4)z= (1+i)z/sqrt(2) f^-1(z)=(1+i)(z-i)/sqrt(2) + i which equals (1+i)z+i*sqrt(2)-i+1/sqrt(2) |
| Sep30-08, 10:09 PM | #4 |
I don't understand your notation.
what is f(z) z-i ? To rotate 45 degrees multiply by e^(i*theta), where theta is in radians. 45 degrees is equal to pi/4 radians. |
| Sep30-08, 10:17 PM | #5 |
right, i don't understand how the book's example came out with sqrt(2) at the bottom
| Sep30-08, 10:28 PM | #6 |
oh sorry, i realized that i forgot equal signs
| Oct3-08, 01:12 AM | #7 |
You're notation is still hard to follow. For instance, the letter z is usually used to express a complex number. z = x+iy.
There are some basic tools you need to perform operations on complex numbers. 1 Euler's Equation. [tex]\ e^{i \theta} = cos(\theta) + i sin(\theta) [/tex] Where [tex]x=cos(\theta)[/tex] and [tex]y= sin(\theta)[/tex], a number in the form [tex]X+iY[/tex] can be expressed in the form [tex]\ Z e^{i \Theta}[/tex]. (In this case 'Z' is a magnitude, a real positive value--so much for conventions.) X,Y,Z, and theta are all real valued numbers, and Z is positive. 2 Complex Conjugation. The complex conjugate of [tex]\ X+iY[/tex] is [tex]\ X-iY[/tex]. You just negate the imaginary part to get the complex conjugate. 3 Division. [tex] c = a+ib [/tex] [tex] z = x+iy [/tex] What is the value of c/z expressed in the form X+iY ? [tex]\frac{c}{z} = \frac{a+ib}{x+iy} [/tex] Multiply the numerator and denominator by the complex conjugate of the denominator. [tex]\frac{c}{z} = \frac{(a+ib)(x-iy)}{(x+iy)(x-iy)}[/tex] [tex]\ \ \ \ \ \ = \frac{(a+ib)(x-iy)}{x^2 + y^2}[/tex] [tex]\ \ \ \ \ \ = \frac{(ax+by) + i(bx - ay)}{x^2 + y^2}[/tex] [tex]\ \ \ \ \ \ = \frac{ax+by}{x^2 + y^2} + i \frac{(bx - ay)}{x^2 + y^2}[/tex] |
| Oct3-08, 12:58 PM | #8 |
I'm confused as to what you mean by "rotating a point". Do you mean rotate around the origin? If you mean "rotate the point 2+ i 90 degrees about the origin", you don't need a formula for a general rotation. Rotating the x-axis 90 degrees takes it into the positive y-axis. Rotating the positive y-axis 90 degrees takes it into the negative x-axis. That is, the point (x,y) is rotated into the point (-y, x).
| Oct4-08, 06:21 AM | #9 |
It sounds as though you're trying to rotate the complex plane around the point 2+i, rather than rotating the point 2+i around the origin. In this case you're doing the right thing: Given a complex number z, you first translate so that 2+i is at the origin (ie subtract 2+i) then you rotate by 90 degrees (ie multiply by i) and finally you translate back so that the point 2+i is back where it started. Step-by-step:
z -> z - (2+i) z -> iz z -> z + (2+i) so if you combine all of these into a single mapping you get z -> iz + 3 - i You can check that plugging 2+i into this formula just gives you 2+i back. If you wanted to rotate by an arbitrary angle theta, then you replace step 2 by z -> exp(i*theta) z |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Rotations in Complex Plane
| Subatomic rotations in a plane Abelian group | High Energy, Nuclear, Particle Physics | 2 | ||
| Subatomic rotations in a plane Abelian group | Advanced Physics Homework | 1 | ||
| Subatomic rotations in a plane Abelian group | Atomic, Solid State, Comp. Physics | 0 | ||
| Complex Plane | Precalculus Mathematics Homework | 8 | ||
| Locus complex plane | Introductory Physics Homework | 6 | ||
