Rate of change of height and angle of elevation.
The discussion focuses on calculating the rate of change of height of a balloon rising vertically, given that the angle of elevation from an observer is increasing at 0.9 degrees per second when the angle is 45 degrees. The initial calculations incorrectly yield a rise rate of 360 m/s, which is not consistent with the expected height change. The correct approach requires converting the angle from degrees to radians and applying the derivative formula h' = 200sec²(θ)θ' for accurate results.
  • Understanding of trigonometric functions, specifically tangent and secant.
  • Knowledge of derivatives and their application in related rates problems.
  • Ability to convert angles from degrees to radians.
  • Familiarity with the concept of angle of elevation in relation to height and distance.
  • Learn how to apply related rates in calculus problems.
  • Study the conversion between degrees and radians in trigonometry.
  • Explore the use of derivatives in real-world applications, particularly in physics.
  • Investigate the implications of angle of elevation in various observational contexts.
Students studying calculus, physics enthusiasts, and anyone interested in understanding related rates and trigonometric applications in real-world scenarios.
bri.nguy
A balloon is rising vertically from a point on the ground that is 200m from an observer at ground level. The observer determines that the angle of elevation between the observer and the balloon is increasing at a rate of 0.9 degrees/s when the angle of elevation is 45 degrees. How fast is the balloon rising at this time?
Don't know, other than trig ratios and derivatives.
Rate of change of height wrt angle of elevation
h=200tan (thetha)
h'=200sec^2(thetha)
(thetha) = 45
h' = 400 m/degree
400m/degree * .9 degree / s = 360 m/s
Now intuitively this makes no sense because, the difference in height of 45 and 45.9 degrees is about 6m not remotely close to 400...Please help, thanks in advance.
Welcome to PF!
h=200tan (thetha)
h'=200sec^2(thetha)
(thetha) = 45
h' = 400 m/degree
Hi bri.nguy! Welcome to PF! :smile:
(have a theta: θ :smile:)
You need to convert θ from degrees into radians. :wink:
(and btw, it should be h' = 200sec^2θ θ')
