Why is the Voltage Negative in this Superposition Theorem Circuit?
  • Thread starter Thread starter Iyafrady
    Negative Voltage
The discussion centers on the negative voltage observed in a circuit analyzed using the superposition theorem. The calculations reveal that the voltage due to the voltage source (Vth1) is 2.14V, while the voltage across the 5kΩ resistor due to the current source (Vth2) is -10V. The resultant voltage (Vth) is calculated as -7.86V. The negative voltage arises because the current flow from the current source is opposite to that of the voltage source, leading to a lower potential at the measurement point, which is referenced to ground.
  • Understanding of the superposition theorem in circuit analysis
  • Familiarity with voltage and current sources
  • Knowledge of Ohm's Law and basic circuit components
  • Ability to interpret circuit diagrams and voltage measurements
  • Study the superposition theorem in detail with practical examples
  • Learn about the implications of ground reference in circuit analysis
  • Explore the concept of voltage polarity and its significance in circuit design
  • Investigate other circuit analysis techniques such as nodal and mesh analysis
Electrical engineering students, circuit designers, and anyone interested in understanding voltage behavior in complex circuits using the superposition theorem.
Iyafrady
Why is this voltage negative??
http://qaboard.cramster.com/answer-board/image/96937de22e44b1524804f2cf580462fe.jpg
Using superposition theorem
With voltage source only,
Vth1 = (3)(5000) / (2000+5000) = 2.14V
With current source only
Current through 5kΩ resistor
I = (0.007)(2000) / (2000+5000) = 2mA
The voltage across it will be
Vth2 = - (0.002)(5000) = -10V why is this voltage negative??
The resultant voltage is
Vth = Vth1 + Vth2
Vth = 2.14 - 10 = - 7.86V
Vth = Vth1 + Vth2
The direction of current flow through the resistor (due to the current source) is the opposite of that due to the voltage source. As the voltage measurement is (implicitly) with the "-" terminal on the shared node on the bottom, this makes the voltage due to the current source negative.
EDIT: Not implicit measurement, I missed the ground symbol on the bottom node. The more intuitive way of realizing that there is a negative voltage is that current flows from higher potential to lower. And then realize that if the higher potential is zero (ground) then the lower potential must be negative.
  • · Replies 28 ·
  • · Replies 59 ·
22K
  • · Replies 16 ·
