How Can I Build a High-Pressure Chamber for Chemical Reactions at Home?
This discussion focuses on constructing a high-pressure chamber for chemical reactions at home, emphasizing the need for a metal structure to withstand elevated pressures and temperatures. Participants suggest using a glove box as a potential solution, highlighting its utility in maintaining controlled environments for reactions. The conversation leans towards practical advice, with an emphasis on safety and feasibility for home experimentation.
  • Understanding of basic chemical reaction principles
  • Familiarity with pressure measurement and control techniques
  • Knowledge of materials suitable for high-pressure applications
  • Experience with basic metalworking tools and safety protocols
  • Research designs for DIY high-pressure chambers using stainless steel
  • Learn about pressure regulators and their applications in chemical reactions
  • Explore safety measures for conducting high-pressure experiments at home
  • Investigate the construction and use of glove boxes for controlled environments
Chemistry enthusiasts, DIY experimenters, and hobbyists interested in conducting high-pressure chemical reactions safely at home.
kateman
Hello!
I was wondering how I could make a pressure chamber to aid some chemical reactions? The higher the pressure I'd be able to put into the better, although I am not really concerned as I don't particually have anything in mind. I'd probably like to be able to heat it up a bit - if the reaction required so - so something made of metal would be ideal.
I don't mind if it is more theoretical than practical information but I would preffer practical, say something that I could do at home [regardless of its difficulty].
Any ideas are welcome,
Thanks!
Chemistry news on Phys.org
Glove box?
Could you explain this a bit please? How would I be able to pressurise it?
  • · Replies 28 ·
  • · Replies 39 ·
  • · Replies 19 ·
11K
