Clocks out of Sync (Special Relativity)
The discussion revolves around the implications of special relativity, specifically focusing on the synchronization of clocks on moving rulers and the effects of time dilation and length contraction. Participants explore how to apply Lorentz transformations to determine the time readings of clocks on a moving ruler as observed from a stationary frame.
  • Participants attempt to apply Lorentz transformations to calculate the time differences between clocks on moving and stationary rulers. Questions arise regarding the correctness of their calculations and the interpretation of time readings.
Several participants are actively engaging with the problem, presenting calculations and questioning their own reasoning. There is a mix of interpretations regarding the application of time dilation and the order of time readings, with some participants seeking confirmation of their methods.
Participants are working under the constraints of special relativity, specifically considering the effects of relative motion on time and length measurements. There is an emphasis on ensuring that assumptions about simultaneity and clock synchronization are critically examined.
Fusilli_Jerry89
There are 2 identical 1m rulers (same rest length), and one if going past the other at some velocity. Each ruler has a clock every 10 cm. According to the fixed clock, the moving ruler's clocks will appear to be moving slow, and out of sync. (if t=0 when the rulers pass each other, then the front of the moving ruler will have t' equal to some negative time, the clock at the back of the moving ruler will read some positive t', and the clock in the middle will read t' = 0 when the fixed ruler's clock reads t=0.
My question is, how do we apply time dilation (or lorentz transformations) to this problem in order to find out exactly how far ahead in time the back of the ruler is, and how far in time behind the front of the ruler is.
K, so say we have two 4 meter long rulers. One is going past the other at 3/5 c. From one ruler's frame: both backs of the 2 rulers line up at x=x'=0 and t=t'=0. If we want to find the time that the contracted ruler's front clock will read to the other ruler, is this how we would do this?:
gamma = 5/4
lorentz transormations:
x'=(5/4)(x-vt)
x' is 4 since this is the length of the moving ruler in it's frame.
4 = (5/4)(x) (since t = 0 all along the ruler in it's own frame)
hence x = 16/5 m
I could have also just used length contraction 4/(5/4) = 16/5 m
Next: I used the lorentz transformation for time:
t'=(5/4)(t-vx/c^2)
t' = 0 since this is the time all along the ruler in the moving ruler's frame
v= 3c/5
x = 16/5 m (as calculated above)
0 = (5/4)(t - (3/5c)(16/5))
t = 48/25c sec
Is this right, or am I missing something?
Thx.
wait a sec, I think I may have gotten my t's backwards.. Did I?
so I reversed my t's and did the following:
Looking for t'
t' = (5/4)(-vx/c^2) (since t = 0 everywhere on the ruler)
t' = (5/4)(-48/25c)
= -12/5c sec <------------ which makes sense since it should be a negative time anyway... I think I forgot about that above lol.
Just to check, which method is right?? (I think it's this one)
uncontracted meter stick=5 m
gamma=5/4
v=3/5
in the stationary meter sticks frame at t=0:
one end of stationary meter stick (0,0)
other end of stationary meter stick (5,0)
one end of moving meter stick (0,0)
other end of moving meter stick (5/gamma,0)=(4,0)in the moving meter sticks frame:
first end of moving meter stick (gamma*(0-v(0)), gamma*(0-v(0)))=(0,0)
other end of moving meter stick (gamma*(4-v(0)), gamma*(0-v(4)))=(5,-3)the whole thing boils down to -gvd
(gamma*d)=uncontracted length
btw. nice choice of gamma/velocity.
the whole thing boils down to -gamma*d*v
(gamma*d)=uncontracted length (that should be easy to remember)
  • · Replies 32 ·
  • · Replies 67 ·
  • · Replies 67 ·
