How to Calculate Arc Length for Parametric Curves in 3D Space?
The discussion focuses on calculating the arc length for parametric curves in 3D space, specifically using the functions x = (u² + v²)/2, y = uv, and z = (2t^(3/2))/3. The arc length is derived from the formula ds² = dx² + dy² + dz², with scale factors identified as h₁ = hₘ = √(u² + v²), h₂ = hₘ = √(u² + v²), and h₃ = hₓ = 1. The integration of ds is simplified by expressing it in terms of dx, dy, and dz, leading to a more efficient single integration method rather than three separate integrations.
  • Understanding of parametric equations in 3D space
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of curvilinear coordinates and scale factors
  • Proficiency in manipulating derivatives and differentials
  • Study the derivation of arc length for parametric curves in 3D space
  • Learn about curvilinear coordinates and their applications in calculus
  • Explore integration techniques for multivariable functions
  • Investigate the use of scale factors in differential geometry
Students and educators in mathematics, particularly those studying calculus and differential geometry, as well as professionals involved in computer graphics and physics simulations requiring 3D curve analysis.
DarkSamurai
[tex]x = \frac{u^{2} + v^{2}}{2}[/tex]
[tex]y = uv[/tex]
[tex]z = z[/tex]
Find the arc length given:
[tex]u(t) = cos(t), v(t) = sin(t), z = \frac{2t^{\frac{3}{2}}}{3}[/tex]
[tex]ds^{2} = dx^{2} + dy^{2} + dz^{2}[/tex]
In curvilinear coordinates thhis becomes
[tex]ds = \sqrt{h^{2}_{1}du^{2}_{1} + h^{2}_{2}du^{2}_{2} + h^{2}_{3}du^{2}_{3}}[/tex]
First I need to get the scale factors, so I took the derivative of each x, y, z component.
I came up with:
[tex]dx = udu - vdv[/tex]
[tex]dy = vdu + udv[/tex]
[tex]dz = dz[/tex]
I then found the scale factors,
[tex]h_{1} = h_{u} = \sqrt{u^{2} + v^{2}}[/tex]
[tex]h_{2} = h_{v} = \sqrt{u^{2} + v^{2}}[/tex]
[tex]h_{3} = h_{z} = 1[/tex]
Then we inject the scale factors into the element arc length formula.
I'm not sure what to do about du1, du2, and du3. Are they just dx, dy and dz? And if so, would this mean I have to integrate 3 times to get the arc length?
I'm not entirely sure about what all this stuff about scale factors is, but it seems that your solution is correct ( though I haven't checked everything). In general, the 3 dimensional Euclidean line element is [itex]ds^2 = dx \wedge dx + dy \wedge dy + dz \wedge dz[/itex]. However, since you are considering zero curvature space, the wedges can just be dropped, so that [itex]ds^2 = dx^2 + dy^2 + dz^2[/itex].
Now you've calculated each of dx, dy, and dz in terms of du, dv, dz. To find the line element in the new system, simply plug those expressions directly into the above equation. That is
[tex]ds^2 = dx^2 + dy^2 + dz^2[/tex]
[tex]= (u du - v dv)^2 + (udv + v du) + dz^2[/tex]
[tex]= (u^2+v^2) du^2 + (u^2 + v^2) dv^2 + dz^2[/tex]
which is exactly what you have.
Now for finding the arclength, you want to integrate ds, that is [itex]s = \displaystyle \int ds[/itex]. You could indeed integrate three times, though this would be very inefficient. Instead, consider the following.
For simplicity of notation, let the line element be [itex]ds = \sqrt{ dx^2 + dy^2 + dz^2}[/itex]. Now let's multiply by one, in the form of [itex]\frac{dx}{dx}[/itex]. That is
[tex]\sqrt{ dx^2 + dy^2 + dz^2} \frac{dx}{dx} = \sqrt{ \frac{dx^2}{dx^2} + \frac{dy^2}{dx^2} + \frac{dz^2}{dx^2} } dx[/tex]
[tex]= \displaystyle \sqrt{ 1 + \left( \frac{dy}{dx} \right)^2 + \left( \frac{dz}{dx} \right)^2 } dx[/tex]
It's easy enough to calculate dy/dx and dz/dx, and now you need only do one integration.
