| Thread Closed |
How do you convert Density into moles? |
Share Thread | Thread Tools |
| Oct9-08, 07:48 PM | #1 |
When 10.00 mL of a solution of strong acid is mixed with 100.00 mL of a solution of weak base in a coffee-cup calorimeter, the temperature falls from 25.7oC to 20.7oC. Determine q for the acid-base reaction, assuming that the liquida have densities of 1.00 g/mL and the same heat capacities as pure water. 2. Relevant equations So I see that you're supposed to use the Q = (Change in T)(N)Molar Heat Capacity of H2O) but they've given the density of water so we're supposed to convert that into moles. I'm obviously doing something wrong, but does anyone know how to convert the density into moles? Density = Mass (g) / Volume (L) moles = Mass(g) / Molar Mass (g/m) |
| Oct10-08, 01:53 AM | #2 |
Admin
You can't convert just density into moles. Density is an intensive property, number of moles is an extensive property, they are not related.
However, you are given extensive property - that is volume. You will need that. |
| Oct13-08, 03:02 AM | #3 |
I think the easiest way to solve this problem is to avoid moles alltogether. Specific heats are _usually_ expressed as J/Kg/C, so moles aren't required unless you want them to be.
You know what your total mass of solvent is and it's specific heat, so finding the energy released with the change in temperature should be trivial. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How do you convert Density into moles?
| Help finding moles of pain killer/moles of hydrogen ion in a pain killer w/ titration | Biology, Chemistry & Other Homework | 3 | ||
| How to convert density from mol/L to kg/m3? | General Engineering | 2 | ||
| calculating the redshift at which radiation energy density equaled mass density | Cosmology | 4 | ||
| convert linear density to area and volumetric density? | Introductory Physics Homework | 3 | ||
| Moles in a Cat | Introductory Physics Homework | 2 | ||
