Can Quantum Computers Use Alternatives to Qubits for Entanglement?
Quantum computers traditionally utilize qubits defined by up/down spins to represent bits |0> and |1> in entangled states. However, alternative two-level systems can serve as qubits, provided they meet specific criteria, such as having energy scales significantly larger than kBT and being decoupled from environmental influences. Josephson junctions are highlighted as effective for creating superconducting qubits due to their non-linear properties, which allow for anharmonic potentials. Additionally, emerging research explores micro-mechanical resonators as potential qubit systems, although achieving quantum regime states remains a challenge.
  • Understanding of quantum mechanics principles, particularly entanglement and superposition.
  • Familiarity with qubit implementations, specifically superconducting qubits and Josephson junctions.
  • Knowledge of energy scales in quantum systems, particularly the significance of kBT.
  • Basic comprehension of quantum state manipulation techniques using electric and magnetic fields.
  • Research the properties and applications of Josephson junctions in superconducting qubits.
  • Explore the concept of anharmonic potentials and their role in quantum computing.
  • Investigate the use of micro-mechanical resonators for qubit development and their current research status.
  • Learn about the implications of using alternative two-level systems in quantum computing beyond traditional qubits.
Quantum physicists, researchers in quantum computing, and engineers developing next-generation quantum technologies will benefit from this discussion.
LaserMind
Quantum Computers use Qubit with Up Down spin to holds bits |0> and |1> for entangled particles in a Bell state. Is this the only way of doing it?
Well, yes and no.
In theory ANY two-level system can be used as a qubit although in reality there are of course many practical problems. When dealing with macroscopic systems (e.g solid state qubits) some of the requirements are
*All relevant energy scales should be much larger than kBT
*The levels used to implement the qubit should as far as possible be decoupled from the environment and have a level splitting that differs from the splitting to the next level (otherwise the probability of leaving the 2-level "subspace" become significant), this means that harmonic potentials can't be used since all levels are equidistant.
This is incidentally why Josephson junctions are used to make superconducting qubits, they are very non-linear devices and can be used to create various anharmonic potentials.
*You also need to be able to the interaction on/off so that you can both manipulate the system when needed AND let it evolve freely; this is usually done using electric/magnetic fields (even when microscopic qubits are used, e.g. electron or atomic spins).
The point here is that you don't need to use "particles" at all. The fact that we talk about up/down spins, use the Palis matrices etc for all types of qubits is simply due to the fact that it is convenient and the math is the same; it does not imply that there are real particles involved, and the "spin" can be a circulating current, the state of a Josephson junction, the number of electrons on an island etc.
Note that some people are even trying to create qubits using micro-mechanical resonators where the two states would simply correspond to different vibrational modes (although so far no one has even been able to get them into the quantum regime, but this is just a matter of time).
f95toli said:
Well, yes and no.
Say a sound wave where Bit 1 = 180 degrees phase and Bit 0 = 0 degrees phase -
hmmmm... that's a revelation to me if its true!
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 42 ·
