Poissons' equation of find potential
  • Thread starter Thread starter FourierX
    Potential
The problem involves two infinite parallel plates separated by a distance with specified potentials and a varying space charge density. The objective is to apply Poisson's equation to determine the potential in the region between the plates.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Poisson's equation and its implications for the potential V. There are attempts to clarify the correct form of the equation and the dependencies of V on spatial variables.
Some participants have resolved initial misunderstandings regarding the equation but continue to seek clarity on the dependencies of the potential. Hints have been provided to guide the original poster towards a more focused approach.
There is a noted confusion regarding the charge densities on the plates and the implications for the potential, as well as the specific dependencies of the potential on spatial dimensions.
FourierX
Two infinite parallel plates separated by a distance s are at potentials 0 and V_o.
a) Use poisson's equation to find the potential V in the region between the plates where the space charge density is [tex]\rho[/tex] = [tex]\rho_o[/tex](x/s). The distance x is measured from the plate at zero potential.
[tex]\nabla[/tex][tex]^{2}[/tex] V = -[tex]\frac{1}{\epsilon_o}\rho[/tex]
I used the Poisson's equation as stated but could not really get logical looking V. Charge densities on the plates are pain in the neck also.
The equation you list under 2., is not Poisson's equation. Poisson's equation will be simple for this case.
thanks brogwal, i resolved my equation, that was blunder. But i am stuck again :(
Hint: is V going to depend on y and z?
No, V does not depend on y and z. I did not get the hint :c
Just write out the equation for V in the case it depends only on x [you do know what [itex]\nabla^2[/itex] stands for I hope!]. I'm sure you can solve that equation.
