What Is the Tension in Two Ropes at Angles?
  • Thread starter Thread starter Darunia9
    Angles Tension
The discussion revolves around a physics problem involving a helium balloon secured by two ropes at an angle, requiring the calculation of tension in the ropes. The problem includes forces acting on the balloon, specifically an upward force and the weight of the balloon.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the equilibrium of forces in both vertical and horizontal planes, questioning how to account for the angles of the ropes. There is discussion about the components of tension and how they relate to the forces acting on the balloon.
Participants are actively engaging with the problem, sharing various interpretations of the forces involved. Some have suggested methods for calculating the tension, while others express confusion about the relationship between the components of tension and the overall tension in the ropes. There is no explicit consensus on the correct approach or final answer.
Participants note discrepancies between their calculations and the book's answer, leading to discussions about assumptions such as the value of gravitational acceleration. There is also mention of the need for a diagram to clarify the relationships between the forces.
Darunia9
This question really confuses me, I have got answers before but they don't fit with the answer in the book and it's due tomorrow
A large helium balloon is attached to the ground by two fixing ropes. Each rope makes an angle of 50 degrees with the ground. There is a force F vertically upwards of 2.15x10^3 N. The total mass of the balloon and it's basket is 1.95x10^2 kg
Find the tension in either rope
I'm not sure what equation to use, in my book there's only upthrust = weight + tension which doesn't work with angles, and the equilibirum equations are explained properly in my textbook
tension = upthrust - weight
=2.15x10^3 - 1911
=239
239/2 = 119.5
but the answer in the book says it should be 131 N
Please help.
Sum up the forces in each plane (x and y) and make them equal zero.
So you have, upthrust = weight + 2tensiony
and tensionx - tensionx = 0
Solve the simultaneous eqn
How would I work out the tension in x, as there is no stated force going along horizontally?
Well you've done it yourself!
Look, nothing is moving in the x direction, however both ropes have x components, that means that the x components must be equal and opposite, to cancel each other out.
erm I'm still really confused so the tensiony = 119.5, right?
I don't see how the x part comes into it, or how to achieve it
I know they cancel each other out but for all I know it could be +1 -1 :confused:
Uh, sorry I have this terrible habit of not reading the question properly haha, it didn't click to me that their angles are the same.
Well the y tension is 119.5, so you just need to calculate the magnitude of tension in the rope, however this won't give 131.. closer to 150 by my guess, perhaps try it incase my estimate is wrong
I can see the problem. They take gravity as 10ms-1
Finding the y component of tension again, then finding the total tension will yield 130.5N
ahh I did think the books answer may be wrong
so the magnitude of the tension in the rope would be sin 50 x 199.5 = 152.8?
No... Perhaps it would help you if you drew a diagram.
The hypotenuse is what you're trying to solve, and we have the opposite length.
so it will be [tex]\frac{200}{2sin(50)} = 130.5N[/tex]
ohh, right thank you
I forgot the way of re arranging the trig function
No worries! I hope it all makes sense.
9K
9K
