Pool ball collision, kinetic energy
The discussion centers on the collision between two pool balls, where one ball travels at 2.5 m/s and strikes a stationary ball, resulting in an angle of 30° and a speed of 1 m/s for the original ball. The calculations reveal that the second ball moves at -17° and 1.71 m/s, with kinetic energies of 0.531 J before and 0.334 J after the collision, indicating energy loss. The conversation clarifies that the setup assumes an inelastic collision, as a perfectly elastic collision would require specific constraints not present in the scenario.
  • Understanding of conservation of momentum
  • Familiarity with kinetic energy calculations
  • Knowledge of elastic vs. inelastic collisions
  • Basic physics of two-dimensional collisions
  • Study the principles of elastic collisions in detail
  • Learn about conservation of momentum in two dimensions
  • Explore real-world applications of collision physics in sports
  • Investigate the properties of materials affecting elasticity
Physics students, educators, and anyone interested in the mechanics of collisions, particularly in sports like billiards.
krausr79
I cooked up an example of a collision between 2 pool balls: one comes in from the right at 2.5 m/s and hits a stationary one. The original goes off at 30° up, 1m/s. What does the lower one do? I calculated the lower one to go down -17°, 1.71 m/s using conservation of momentum/ simultaneous equations. Then I calculated kinetic energies to be .531 before and .334 after (mass of pool balls assumed at .17kg)
My question is about elasticity. I didn't make any assumptions about it, so I expected to get a perfectly elastic collision (kinetic energy preserved). I've also read that pool balls are mostly elastic. Does this mean that my problem setup assumes an inelastic collision? Would it be impossible to get a pool ball collision like this in real life?
pstart = pfinal
KE = 1/2MV2
Hi krausr79,
A perfectly elastic collision is a special case, so you would need to constrain your problem for it to be elastic.
Yes.
If these identical balls were assumed to be particles colliding elastically (with one initially at rest), the angle between the final velocities would be ninety degrees; this is very different from the 47 degrees that you found in your problem.
Ok, thanks.
  • · Replies 22 ·
