Drag care race, finding distance and time
  • Thread starter Thread starter Prio
    Drag Race Time
The discussion revolves around a physics problem involving two race cars, CAR A and CAR B, with different accelerations. CAR A accelerates at +5.9 m/s² while CAR B accelerates at +3.6 m/s² and has a 1-second head start. The user initially attempts to calculate the time it takes for CAR A to overtake CAR B using the equations of motion, specifically the formulas for final velocity and distance. The user concludes that the time for CAR A to overtake CAR B is approximately 8.91 seconds, but later realizes a mistake in the initial distance calculation for CAR B.
  • Understanding of kinematics and equations of motion
  • Familiarity with acceleration and initial velocity concepts
  • Ability to solve quadratic equations
  • Knowledge of basic physics principles related to motion
  • Review the kinematic equations for uniformly accelerated motion
  • Learn how to set up and solve quadratic equations in physics problems
  • Explore the concept of relative motion in physics
  • Practice similar problems involving multiple objects with different accelerations
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of motion problems involving acceleration and time calculations.
Prio
EDIT***: sorry I figured out how to do this problem and don't need help anymore...:\
Disregard and even delete this thread.
A race-car driver buys a car (CAR A) that can accelerate at +5.9 m/s2 . The racer decides to race against another driver with a car (CAR B) that can move with a constant acceleration of +3.6 m/s2. Both start from rest, but CAR B leaves 1.0 s before the driver of CAR A.
Find the time it takes CAR A to overtake CAR B
Find the distance the two drivers travel during this time.
Find the velocities of both cars when they are side by side.
I'm not sure if this is what to use, but
Final velocity = Initial velocity + at
or maybe
d = (initial velocity)(t) + 1/2 (a)(t)2
Because car B has a 1 second lead, it will have established a 3.6 m lead on car A and already entered acceleration when car A gets off the line. I would think then that car B has an initial velocity of 3.6 while car A's is 0. I'm trying to find t where d1=22
So d1 = 0 + 1/2 (5.9)(t)2
d2 = 3.6 + 1/2 (3.6)(t)2
if these are set equal to equal to each other and the first is solved for t, I get t2=2.95
then I plugged this number into the t2 in the other equation and get 3.6 + 1/2(3.6)(2.95)
= 8.91s
Did I do this right?
vvvvv
You can do it this way if you like it.
The distance traveled by the first car in 1 s is not 3.6 m. Look again at your second formula.
Then, when you write again the distance traveled by the first car, it has an initial velocity of 3.6 m/s. You should have this term too (x=xo+vo*t + 1/2 a*t^2)
  • · Replies 20 ·
