Wigner-Seitz = Brillouin Zone?
The discussion revolves around the relationship between the Wigner-Seitz cell and the first Brillouin zone, focusing on the methods for constructing these geometrical entities in both real and reciprocal space. Participants explore the algorithms for determining the first Brillouin zone and whether they yield equivalent results.
  • One participant expresses confusion about the equivalence of the Wigner-Seitz cell and the first Brillouin zone, questioning if the two algorithms for finding the Brillouin zone are equivalent.
  • Another participant asserts that the Wigner-Seitz cell in the reciprocal lattice is indeed the first Brillouin zone.
  • A different participant seeks clarification on whether the Wigner-Seitz cell is constructed in the reciprocal lattice or if it is derived from a real-space construction transformed into k-space.
  • Another participant confirms that the Wigner-Seitz cell should be constructed in the reciprocal lattice to obtain the first Brillouin zone, suggesting a similar algorithm to that used in real space.
Participants exhibit disagreement regarding the methods of construction and the interpretation of the relationship between the Wigner-Seitz cell and the first Brillouin zone. There is no consensus on whether the algorithms are equivalent or which method is correct.
Participants do not fully resolve the assumptions underlying the construction methods or the definitions of the Wigner-Seitz cell and Brillouin zone, leaving some ambiguity in their discussion.
andrewm
I am confused about the relation between the Wigner-Seitz cell and the first Brillouin zone.
My teacher explained that to find the Wigner-Seitz cell in real space, one draws lines between the lattice points and connects the perpendicular bisecting planes. This constructs the volume nearer to any point in real space than any other point.
My confusion arises from people saying "The Wigner-Seitz cell in the reciprocal lattice is the first Brillouin zone". Isn't that unclear?
Are the two algorithms equivalent for finding the first Brillouin zone?
Algorithm 1:
1. Transform spatial vectors to reciprocal vectors. Put a "dot" at the tip of each reciprocal vector.
2. Find the Wigner-Seitz cell in this new lattice by finding the volume closer to any dot than any other dot.
3. This cell is the first Brillouin zone.
Algorithm 2:
1. Find the Wigner-Seitz cell in real space.
2. Draw a vector to each point on the Wigner-Seitz surface.
3. Transform these vectors to reciprocal vectors using the usual 3 cross- and triple-product equations
4. The surface made up of the tips of these vectors is the first Brillouin zone.
So, are these the same thing? Which is correct?
Is a correct statement.
Yes, but does it mean that the Wigner-Seitz cell is constructed in the reciprocal lattice and that is the zone? Or that the Wigner-Seitz cell, constructed in real space, is then transformed to k-space, and that is the zone?
You construct the wigner-seitz cell in the reciprocal lattice = 1st Brilloun zone.
So first obtain the reciprocal lattice, then perform the same algorithm as you would have done to get the wigner-seitz cell in the "position lattice", but in the reciprocal space instead of the position lattice space.
Excellent, thanks.
  • · Replies 18 ·
9K
