Induced current through a resistor - with variable resistor and two coils
The problem involves two coaxial solenoids and a variable resistor in one of them. The original poster is trying to understand how the induced current through a resistor is affected as the resistance is increased at a constant rate.
  • Participants discuss the implications of Lenz's Law and the relationship between current and magnetic fields in the coils. There are attempts to clarify the direction of current flow and magnetic fields, as well as the effect of the variable resistor on the induced current.
Participants are actively engaging with the concepts and questioning the relationships between the variables involved. Some have provided guidance on how to approach the problem using Lenz's Law, while others are exploring the implications of changing resistance on the magnetic field and induced current.
There is a time constraint mentioned, as the original poster needs assistance by noon. The discussion also highlights uncertainty regarding the role of the variable resistor and its impact on the induced current in the second coil.
jcvince17
The two solenoids in the figure are coaxial and fairly close to each other.
While the resistance of the variable resistor in the left-hand solenoid is increased at a constant rate, the induced current through the resistor R will
A - flow from a to b.
B - flow from b to a.
C - be zero because the rate is constant.
I recall something about Lenz Law stating if the current is constant there will be no induced emf, so C is not correct.
If the current is increasing the emf is opposite to I. If the current is decreasing the emf is in same direction as I.
I cannot find anything in my book about this variable rersistor and am having a hard time with this right hand rule for induced current.
If someone can please help me derive at this answer I will greatly appreciate it.
Start by thinking about what happens to the current (and therefore the magnetic field) in the coil on the left.
The current will flow from left to right correct? and magnetic field into the page?
this new right hand rule has me off. I am to place my thumb in direction of B and curl my fingers into the induced I? therefore the current on coil 1 will flow in a clockwise direction?
Correct on the current. As for the magnetic field: look at how the current is flowing through the coil. The magnetic field will be either to the left or right, not into/out of the page.
current to the right and magnetic field going to the left. right?
if this is true (what i posted above here) then would the current in coil loop two flow from b to a?
Yes.
... would the current in coil loop two flow from b to a?
You've made a big jump without explaining any intermediate steps.
How does B change, given what Rvar is doing? I.e., in what direction is the change in B? (left or right?).
Once you figure that out, you can use Lenz's Law to figure out the direction of the induced current for the right-hand coil and resistor.
honestly i do not know. i was going on the flow of the current in coil (left) and assuming it went from a to b.
i do not know anything about the Rvar. What does it do?
i am not 100% sure how the current in one and two flows to the right. i just looked at the coils and saw its direction, plus the positive side of the battery. I can tell the current should flow in the same direction on each coil.
how does the Rvar have anything to do with coil 2? coil one is creating an induced current on coil 2 but that should be created regardless of the Rvar right? The Rvar should/could not create a negative current; therefore changing the currents direction, so i think the Rvar should not have much of an impact on coil 2 for these reasons?
The only thing I can see the Rvar is doing is changing the current in coil 1.
help?
edit - thinking about Lenz's Law - it tries to keep the magnetic field constant = no change. in order for that to happen we need a B on coil 2 in the right direction. for that to happen we need a current to the right. which would give me flow from b to a.
i still do not know anything about Rvar
this is due by noon today. please.
From the original post:
jcvince17 said:
... the resistance of the variable resistor in the left-hand solenoid is increased at a constant rate ...
if resistance is increased then the current (I) is decreased correct? I= V/R
if the current is decreased in coil 1 then the B of coil 2 is decreased as well right? decreasing B filed to the left.
Not sure if you're still trying to work this one out, but:
Yes.
Yes, B (which points to the left) of coil 2 decreases.
So the direction of dB/dt is _____ ?
Or, asked another way ... suppose for example B changes from -3 Tesla (i.e., 3 Tesla, to the left) to -2 Tesla. The change in B is ____ Tesla, towards the _____ (right/left)?
Yes.
So the direction of dB/dt is _LEFT____ ?
Or, asked another way ... suppose for example B changes from -3 Tesla (i.e., 3 Tesla, to the left) to -2 Tesla. The change in B is _1___ Tesla, towards the _right____ (right/left)?
i filled in above.
here is what was I got from class tonight.
we have a current to the right and B to the left on coil 1. with the variable resistor it is decreasing I which in turn is decreasing B. If we have to "oppose" a decreasing B then the B of coil 2 needs to be to the left as well. (to ADD to the decreasing B currently) in order for this to happen the I on coil 2 must be to the right, therefore flowing from B to A.
correct?
Yes.
my reasoning sound correct also?
thanks for all your help! with me knowing the directions on coil 1 it made it easier to explain what I needed coil 2 to have
You're welcome, and yes the reasoning is correct.
Might be good to specify, when you say current flows from B to A, whether that is the resistor current or the coil current.
  • · Replies 41 ·
9K
